跳转到主内容
Huawei Mate 20 Pro Daughterboard Cover Replacement
你所需要的
  1. Huawei Mate 20 Pro Daughterboard Cover Replacement, Rear Glass: 步骤 1 中的图像 1,1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
  2. Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 2 中的图像 1,3 Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 2 中的图像 2,3 Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 2 中的图像 3,3
    • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner.
  3. Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 3 中的图像 1,2 Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 3 中的图像 2,2
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 4 中的图像 1,3 Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 4 中的图像 2,3 Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 4 中的图像 3,3
    • Insert a third opening pick at the bottom left corner.
    • Slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 5 中的图像 1,2 Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 5 中的图像 2,2
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the back cover.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 6 中的图像 1,2 Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 6 中的图像 2,2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
  7. Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 7 中的图像 1,2 Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 7 中的图像 2,2
    • Lift and remove the back cover.
    • Before installing fresh adhesive and reassembling, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply pressure for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
  8. Huawei Mate 20 Pro Daughterboard Cover Replacement, Motherboard Cover with NFC & Charging Coil: 步骤 8 中的图像 1,1
    • Remove the eight Phillips #00 screws (4.3 mm length).
    Hallo, es sind nur 7 Kreuzschlitzschrauben à 4.3mm. Eine (die zweite von unten links nach rechts) ist massiv kürzer und silbern.Gruss Jörg
    Jörg Schircks - 回复
  9. Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 9 中的图像 1,3 Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 9 中的图像 2,3 Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 9 中的图像 3,3
    • Slide an opening pick under the black adhesive at the bottom left of the charging coil.
    • Carefully slide the opening from the left to the right side to loosen the adhesive.
  10. Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 10 中的图像 1,2 Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 10 中的图像 2,2
    • Insert an opening pick under the bottom left corner of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
    • Do not try to remove the motherboard cover all the way yet. The flex cable of the flash assembly is still connected to the motherboard.
  11. Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 11 中的图像 1,2 Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 11 中的图像 2,2
    • Carefully fold the motherboard cover in the direction of the battery.
    • Take special care to avoid ripping the flash assembly flex cable as it is still connected to the motherboard.
  12. Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 12 中的图像 1,3 Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 12 中的图像 2,3 Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 12 中的图像 3,3
    • Use a spudger to pry up and disconnect the flash assembly flex cable.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Remove the motherboard cover including the NFC and charging coil.
  13. Huawei Mate 20 Pro Daughterboard Cover Replacement, Battery Disconnect: 步骤 13 中的图像 1,2 Huawei Mate 20 Pro Daughterboard Cover Replacement, Battery Disconnect: 步骤 13 中的图像 2,2
    • Use a spudger to pry up and disconnect the battery connector.
  14. Huawei Mate 20 Pro Daughterboard Cover Replacement, Daughterboard Cover: 步骤 14 中的图像 1,1
    • Remove the three Phillips #00 screws (4.3 mm length).
    • If you want to remove or replace the loudspeaker, daughterboard, battery, or the OLED screen, remove the four Phillips #00 screws (4.3 mm length) which hold down the loudspeaker assembly.
  15. Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 15 中的图像 1,3 Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 15 中的图像 2,3 Huawei Mate 20 Pro Daughterboard Cover Replacement: 步骤 15 中的图像 3,3
    在这个步骤中使用的工具:
    • Slide an opening pick under the top right corner of the daughterboard cover.
    • Use the opening pick to pry up the daughterboard cover. Remove the daughterboard cover with tweezers.
结论
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
另外一个人完成了本指南。
Dominik Schnabelrauch
于11/23/16注册
230,403 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,552篇指南
一条评论
Hi there.... My huawei mate 20 pro was water damaged!!! After a while its LCD was displaying green lines and in no time it went blank, but surprisingly the phone works and still receives notifications and incoming calls. I could even answer calls in a blank screen by pretending to swipe as if its on. My question before i buy a replacement screen . Is the LCD really damaged or its the logic board ? This might help me decide on how to proceed with it.
Bhekani Tshuma - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 89
总计 1,521
