跳转到主内容
加入维修社区 - 创建账户
Huawei M750 Button Replacement
你所需要的
  1. Huawei M750 Button Replacement, Battery: 步骤 1 中的图像 1,1
    • Depress the top of the battery cover, and pull downwards towards the base of the phone.
    询问修复机器人
    添加评论
  2. Huawei M750 Button Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by levering the battery out, using the cut just below the camera.
    询问修复机器人
    添加评论
  3. Huawei M750 Button Replacement, Back Panel: 步骤 3 中的图像 1,1
    • Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Work the opening tool around the border of the camera and speaker cover, until it comes loose.
    询问修复机器人
    添加评论
  4. Huawei M750 Button Replacement: 步骤 4 中的图像 1,2 Huawei M750 Button Replacement: 步骤 4 中的图像 2,2
    • Using the T5 Torx screwdriver, remove the six 6mm screws.
    询问修复机器人
    添加评论
  5. Huawei M750 Button Replacement: 步骤 5 中的图像 1,2 Huawei M750 Button Replacement: 步骤 5 中的图像 2,2
    • Using the opening tool, pry the back panel from the front panel.
    • Work your way around the phone until the panels separate evenly.
    • This step may require a substantial amount of leverage.
    询问修复机器人
    添加评论
  6. Huawei M750 Button Replacement, Buttons: 步骤 6 中的图像 1,2 Huawei M750 Button Replacement, Buttons: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to grab hold of each button on an edge from inside of the casing and pull out to remove.
    询问修复机器人
    添加评论
  7. Huawei M750 Button Replacement: 步骤 7 中的图像 1,1
    • If it is the actual main screen panel control buttons that need to be replaced, grab the front panel as seen in the picture and push from the outside in with little pressure as if you were regularly trying to use the button.
    询问修复机器人
    添加评论
  8. Huawei M750 Button Replacement: 步骤 8 中的图像 1,2 Huawei M750 Button Replacement: 步骤 8 中的图像 2,2
    • If the buttons aren't broken and the phone just isn't getting the signal when the button is depressed, try replacing the actual electronic board under the buttons replaced in the last step.
    • Using the plastic opening tool, insert just under the electronic board and apply slight pressure upward.
    • It is snapped in place so it may seem like you have to add a little more pressure than needed. But don't worry, you won't break the board and it will pop right out.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 39
总计 633
