跳转到主内容
加入维修社区 - 创建账户
How to remove malware from an infected windows PC
你所需要的
    1. How to remove malware from an infected windows PC, Install Anti-Malware software: 步骤 1 中的图像 1,2 How to remove malware from an infected windows PC, Install Anti-Malware software: 步骤 1 中的图像 2,2
      • On the PC you will be doing antivirus on, install the appropriate software. If the PC with malware does not turn on, install on a different one to do anti-virus.
      • Malwarebytes is great anti-virus software. Go to the website and install it for free.
      • Glarysoft Malware hunter is also good. Their website is here.
      • Other free anti-malware works too, but these are my favorites.
      询问修复机器人
      添加评论
    2. How to remove malware from an infected windows PC, Remove your SATA HDD/SDD from the PC: 步骤 2 中的图像 1,1
      • This step only applies to PCs that do not boot. If the PC with malware runs, then install the software directly onto it.
      • Because assembly of different laptops and PCs vary so much, you will have to figure out or find a guide to remove your drive.
      询问修复机器人
      添加评论
    3. How to remove malware from an infected windows PC, Connect the drive: 步骤 3 中的图像 1,1
      • This step also only applies to PCs that don't boot.
      • If your non-infected PC is a desktop, you may unplug the optical drive and plug the connections into the HDD or SSD. If it is a laptop, you will need a SATA to USB adapter.
      • Shut down your desktop before unplugging the DVD drive and attaching the HDD.
      询问修复机器人
      添加评论
    4. How to remove malware from an infected windows PC, Disinfect your PC: 步骤 4 中的图像 1,3 How to remove malware from an infected windows PC, Disinfect your PC: 步骤 4 中的图像 2,3 How to remove malware from an infected windows PC, Disinfect your PC: 步骤 4 中的图像 3,3
      • Once you've installed the necessary programs and (if applicable) connected you're infected drive to you PC, you are ready to be the doctor.
      • Run Malwarebytes.
      • Run Glarysoft Malware Hunter.
      • Windows defender comes preinstalled with Windows. Use that also.
      询问修复机器人
      添加评论
    5. How to remove malware from an infected windows PC, Double checking another PCs drive.: 步骤 5 中的图像 1,1
      • This is the last step for checking another PCs drive
      • Go into file explorer, right click on the drive from the infected PC, and select each of the highlighted options.
      询问修复机器人
      添加评论
    6. How to remove malware from an infected windows PC, Finito!: 步骤 6 中的图像 1,1
      • All done! follow these instructions in reverse to put everything back.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
40等其他人完成本指南。
George A.
于12/07/16注册
22,563 声望
创作了4篇指南
团队
Community Protectors Community Protectors 的会员
Community
21 名成员
创作了112篇指南
1指南评论
changed “boot” to “turn on” because it would make more sense to the people who read this article, as they could be the much less computer-savvy people
aaaaaaaaaaaaaaaaa - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 47
过去 30 天: 211
总计 12,461
