此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
有一个齿轮电机负责控制快门释放机制的触发。随着时间推移,该齿轮可能会因过紧而无法转动,或者被灰尘污染。在这种情况下,只需对齿轮进行少量润滑,即可使其恢复正常。
你所需要的
从相机底部右后侧拧下六颗 3 mm x 2.5 mm 十字螺丝。
从相机底部左侧拧下三颗 3 mm x 5.5 mm 螺丝。
提起电池盖板,并从相机底部左侧拧下两颗 3 mm x 5.5 mm 螺丝。
要重新组装设备,请按相反顺序执行这些说明。
11等其他人完成本指南。
2指南评论
I have a d3200 that “at will” will throw this message, so incredibly random. It will be fine then …. the message. Always at the worst moment. I have checked the mirror path and that doesn’t seem to be catching at all. I think I want to try this fix you outlined, but I have. D3200 not a 3000… is everything the same?
Hello there.
I attempt many times to resolve issue on my camera. I tried lubricate red gear wheel, but problem persisting.
Does any other thing I need to do?
