简介
This is a prerequisite guide! This guide is part of another procedure and is not meant to be used alone.
Use this guide to disconnect the battery in your Huawei Watch GT 3 (46mm).
你所需要的
Before starting repairs, take your watch off the charger and power it down.
Remove the watch band.
Remove the four 3.7 mm-long Torx T2 screws securing the back cover.
Insert the edge of a spudger into the the loudspeaker opening at the bottom edge of your watch.
Use a spudger to pry up the rear panel of your Huawei watch GT 3.
Carefully swing the rear panel assembly open to an upward position.
在这个步骤中使用的工具:Tweezers$4.99
Use a pair of tweezers to peel the black tape off the battery connector bracket.
Remove the singe 2.2 mm-long Phillips screw securing the battery connector bracket.
Use a pair of tweezers to remove the battery connector bracket.
Use a spudger to disconnect the rear panel assembly cable by prying the connector straight up from its socket.
Remove the rear panel assembly.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
