简介
VirtualBox is an extremely versatile, and powerful virtualization software, that can allow users to run multiple operating systems on a single physical machine.
Download the VirtualBox software for your machine from here.
Click on the VirtualBox Installer to start the installation wizard. Once the wizard is started you can choose which features are installed.
On the Ready to Install Screen, hit install to start the installation process. After the installation process is finished, you can tick the checkbox for starting the VM is installed.
To create a new virtual machine you can either click on Machine > New, or choose the blue star to create a new VM. The Virtual Machine Wizard will appear, and you will be prompted to click Next.
Once you hit next, you will be prompted to enter a name of your choice for your virtual machine, along with the information for the operating system you wish to virtualize.
You will also have to designate the amount of memory (RAM) you want to the virtual machine to use.
Once the initial properties are set, you will need to allocate the amount of storage you want your virtual machine to have.
Choose the Create a virtual hard disk now option and click Create to proceed.
Select the desired hard disk file type and storage location.
Choose the disk size and storage allocation options, and then click Create to create the virtual hard disk.
Back in the VirtualBox Manager, select the newly created virtual machine and click on the Settings button.
Click on the Start button in the VirtualBox Manager to launch the virtual machine.
Follow the prompts to install the operating system of your choice within the virtual machine.
Insert the installation media (ISO file, CD/DVD, etc.) and proceed with the installation process.
After the operating system installation is complete, you have the option to install VirtualBox Guest Additions.
Select Devices in the VirtualBox menu and choose Insert Guest Additions CD image.
Follow the on-screen instructions to install the Guest Additions.
Once the installation and configuration are complete, you can start the virtual machine by selecting it in the VirtualBox Manager and clicking on the Start button.
Virtual machines provide a flexible and efficient way to run multiple operating systems on a single physical machine, allowing you to explore different environments and perform various tasks.
5等其他人完成本指南。
