跳转到主内容
加入维修社区 - 创建账户
How to create a ChromeOS Recovery USB Drive
你所需要的
      • In order to make your recovery device, you will need the following items.
      • 1 x USB Drive or SD Card (8 GB is the minimum)
      • Any content that is stored on this drive will be erased during the next few steps. Be sure to back up any content you want saved, or make sure this is a drive you are going to use for future devices.
      • 1 x computer running the Google Chrome Browser, or Chrome OS.
      询问修复机器人
      添加评论
    1. How to create a ChromeOS Recovery USB Drive, Download the Recovery Utility: 步骤 2 中的图像 1,2 How to create a ChromeOS Recovery USB Drive, Download the Recovery Utility: 步骤 2 中的图像 2,2
      • Open Google Chrome and navigate to the Chrome Web Store and download the Chromebook Recovery Utility extension.
      • Add the utility to Chrome and launch it. You will be greeted with this page.
      添加评论
    2. How to create a ChromeOS Recovery USB Drive, Enter your Chromebook Model Number: 步骤 3 中的图像 1,1
      • Click on "Get started" and you will be prompted to enter the model of your Chromebook.
      • You have the option of either entering the code that is on the device's recovery screen, or choosing from the model list.
      询问修复机器人
      添加评论
    3. How to create a ChromeOS Recovery USB Drive, Insert your Removable Media: 步骤 4 中的图像 1,1
      • Plug in your spare 8 GB USB Drive and select it from the dropdown menu.
      • Any content that is stored on the drive will be erased during the next few steps. Make sure that the drive is empty, or does not have any data that you don't want to lose.
      询问修复机器人
      添加评论
    4. How to create a ChromeOS Recovery USB Drive, Create Recovery Image: 步骤 5 中的图像 1,1
      • You will be presented with a screen that shows the drive you selected. Click on the "Create now" button and the processes will begin.
      • Do not remove the drive while the process is taking place. The process will take about 5 minutes to complete and you will be prompted when the recovery drive is finished.
      询问修复机器人
      添加评论
结论
If you intend on reusing the drive for storing files you will need to use the Recover Utility application to erase the data on the drive, and you will need to reformat it with a recovery tool.
取消:我没有完成这个指南。
101等其他人完成本指南。
Jacob Mehnert
于10/18/21注册
49,341 声望
创作了51篇指南
团队
iFanatics iFanatics 的会员
Community
69 名成员
创作了382篇指南
15指南评论
Thanks only this is working all the other instructions on google didnt work… Direct and simple instructions
idide akeh - 回复 分享
I'm glad to hear that this guide helped you out!
Jacob Mehnert - 回复 分享
Hello....I followed all you said here yet my USB flash drives got corrupted after the recovery utility completed
Amos - 回复 分享
Hello, you might need to wipe the USB drive and attempt to install the recovery tool again. You might also want to check that the drive is formatted to FAT32. Other formats have been known to cause errors with the recovery tool.
Does it matter if it’s a 2.0 or 3.0 USB drive???
Josh Knapp - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 105
过去 30 天: 552
总计 59,582
