跳转到主内容
加入维修社区 - 创建账户
How to align Razor A steering
你所需要的
    1. How to align Razor A steering, How to align Razor A steering: 步骤 1 中的图像 1,3 How to align Razor A steering, How to align Razor A steering: 步骤 1 中的图像 2,3 How to align Razor A steering, How to align Razor A steering: 步骤 1 中的图像 3,3
      • Locate the collar clamp near the base of the steering column.
      • Insert a 3/16" Allen wrench into the screw in the collar clamp and loosen it.
      • The collar clamp will be free to move and may slide around the steering column. When reassembling, return it to its original position.
      添加评论
    2. How to align Razor A steering: 步骤 2 中的图像 1,2 How to align Razor A steering: 步骤 2 中的图像 2,2
      • Firmly grasp the steering column and turn the wheel by hand.
      • View the scooter along the steering column. Be sure the wheel is perpendicular to the handlebars.
      • The second picture above shows a correct alignment of the steering column from this view.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
17等其他人完成本指南。
Jordyn
于10/09/12注册
565 声望
创作了5篇指南
团队
Cal Poly, Team 9-13, Amido Fall 2012 Cal Poly, Team 9-13, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G13
4 名成员
创作了10篇指南
4指南评论
This is so unhelpful.
Linh Tran - 回复 分享
Great guide! Thanks so much helped me to fix my old scooter and save approx. $50
Max Kittens - 回复 分享
Wow, fixed all the kids scooters on the block….THANK YOU!!!!!
Kathy Earhart - 回复 分享
It worked for me for a little, but after a while the fix stopped working and i am back to where i started, and it is now as tight as it will go. They should really make the scooters better. The guide was really helpful, so thanks so much!
Alan Weinberg - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 24
过去 30 天: 106
总计 32,058
