跳转到主内容
加入维修社区 - 创建账户
How to adjust Razor A steering column
  1. How to adjust Razor A steering column, How to adjust Razor A steering column: 步骤 1 中的图像 1,2 How to adjust Razor A steering column, How to adjust Razor A steering column: 步骤 1 中的图像 2,2
    • Locate the tightening assembly. The tightening assembly consists of:
    • An upper nut
    • A lower nut
    询问修复机器人
    添加评论
  2. How to adjust Razor A steering column: 步骤 2 中的图像 1,1
    • This step refers to clockwise and counterclockwise rotation. This is as viewed from the top.
    • If loosening the steering column, follow these steps:
    • Turn the upper nut counterclockwise.
    • Turn the lower nut counterclockwise until it is tight against the upper nut.
    • If the steering column is still too tight, repeat the above two steps until reaching the desired steering column looseness.
    • If tightening the steering column, follow these steps:
    • Turn the lower nut clockwise until reaching the desired steering column tightness.
    • Turn the upper nut clockwise until it is tight against the lower nut.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
4等其他人完成本指南。
Jordyn
于10/09/12注册
565 声望
创作了5篇指南
团队
Cal Poly, Team 9-13, Amido Fall 2012 Cal Poly, Team 9-13, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G13
4 名成员
创作了10篇指南
8指南评论
what move it with your hands? - didn't help
Heather McCasland - 回复 分享
I couldn't turn this by hand. not sure who writes this advice. trying a pipe wrench.
jmackenzie1234 - 回复 分享
Thanks you! Why doesn't the owners manual have this?
Jessica - 回复 分享
Thanks for the instructions. They helped me fix my son’s scooter.
That Dude - 回复 分享
Thank you for showing the way how to adjust Razor scooter. This instruction help me to adjust my scooter.
Jessie Allen - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 27
过去 30 天: 110
总计 44,102
