跳转到主内容
加入维修社区 - 创建账户
How to Use a Needle Threader
你所需要的
    1. How to Use a Needle Threader, How to Use a Needle Threader: 步骤 1 中的图像 1,2 How to Use a Needle Threader, How to Use a Needle Threader: 步骤 1 中的图像 2,2
      • Take the needle threader in one hand, and the needle in your other hand.
      • Insert the wire loop on the needle threader through the eye of the needle.
      询问修复机器人
      添加评论
    2. How to Use a Needle Threader: 步骤 2 中的图像 1,3 How to Use a Needle Threader: 步骤 2 中的图像 2,3 How to Use a Needle Threader: 步骤 2 中的图像 3,3
      • Hold both the needle threader and needle in one hand, while keeping the loop of wire on the needle threader through the eye of the needle.
      • Insert your thread through the loop of wire on the needle threader.
      • Pull the thread through the loop so that you have a tail of least a few inches in length.
      添加评论
    3. How to Use a Needle Threader: 步骤 3 中的图像 1,2 How to Use a Needle Threader: 步骤 3 中的图像 2,2
      • Fold the tail over to meet the other thread.
      • Hold both lengths of thread together.
      询问修复机器人
      添加评论
    4. How to Use a Needle Threader: 步骤 4 中的图像 1,3 How to Use a Needle Threader: 步骤 4 中的图像 2,3 How to Use a Needle Threader: 步骤 4 中的图像 3,3
      • While holding both threads, pull the wire loop of the needle threader out of the eye of the needle.
      • Once the wire loop is out of the eye, release the tail end of the thread.
      • Pull the needle threader off the thread. This will bring the tail end through.
      添加评论
    5. How to Use a Needle Threader: 步骤 5 中的图像 1,3 How to Use a Needle Threader: 步骤 5 中的图像 2,3 How to Use a Needle Threader: 步骤 5 中的图像 3,3
      • Pull the tail end of the thread until both threads are equal in length.
      • Holding both lengths of thread together, tie a knot near the end and pull it tight.
      • This will trap the needle in the loop of thread and allow you to sew with doubled thread. If you prefer to sew with a single thread, tie a knot in only one of the threads, not both.
      添加评论
终点
取消:我没有完成这个指南。
78等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
91,000 声望
创作了142篇指南
20指南评论
thank you for this
it helped me with
sewing project
Swathika E - 回复 分享
For years I have been doing this the hard way. I had no idea what the threader was. I have thrown so many away not knowing what they were. Thank you so much. You've made what i enjoy doing (sewing projects), even more enjoyable.
Shannon B, 01/06/2016
Shannon Beecham - 回复 分享
Though I had a needle threader but didn't know how to use it ?
Your guidelines really helped me. Thanks a lot.
vickysos - 回复 分享
Thank you. My automatic needle threader on sewing machine is off track and I'm not in the mood to locate online how to fix/correct it today. I had plenty of handheld and long neck serger needle threaders in my stash and couldn't figure out how to thread my needle on sewing machine with the long neck threader, but you helped me with that, thanks.
Bonita W - 回复 分享
Thank you you are a Life saver!!!!
ciaaratpaen - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 97
过去 7 天: 614
过去 30 天: 2,996
总计 621,017
