跳转到主内容
加入维修社区 - 创建账户
How to String a Tennis Racket
你所需要的
    1. How to String a Tennis Racket, Cut the old strings from the tennis racket: 步骤 1 中的图像 1,2 How to String a Tennis Racket, Cut the old strings from the tennis racket: 步骤 1 中的图像 2,2
      • Cut the old strings from the tennis racket using a pair of utility scissors and remove them.
      • Be careful not to cut yourself with the ends of the strings.
      询问修复机器人
      添加评论
    2. How to String a Tennis Racket, Place the frame into a stringing machine: 步骤 2 中的图像 1,1
      • Place the frame into a stringing machine by screwing in the four main screws and pulling the racket tight.
      询问修复机器人
      添加评论
    3. How to String a Tennis Racket, Insert the main vertical string into the head of the racquet: 步骤 3 中的图像 1,3 How to String a Tennis Racket, Insert the main vertical string into the head of the racquet: 步骤 3 中的图像 2,3 How to String a Tennis Racket, Insert the main vertical string into the head of the racquet: 步骤 3 中的图像 3,3
      • Insert the main vertical string into the head of the racket, and thread it down to the neck of the racket and back to the head.
      • Pull and tighten the first main string into a tension rod.
      • The strings should always go under the racquet.
      询问修复机器人
      添加评论
    4. How to String a Tennis Racket, Secure and tighten the end of the string: 步骤 4 中的图像 1,2 How to String a Tennis Racket, Secure and tighten the end of the string: 步骤 4 中的图像 2,2
      • Secure and tighten the end of the string by attaching it to the clamp and moving the rod into the horizontal position.
      • Fix the second string utilizing the second clamp and release the first string.
      • Continue threading the main strings and clamping the strings until all holes have been strung.
      • The stringing pattern: Insert and tighten the string, secure the next string with the clamp, and release the previous string.
      询问修复机器人
      添加评论
    5. How to String a Tennis Racket, Knot the main string: 步骤 5 中的图像 1,2 How to String a Tennis Racket, Knot the main string: 步骤 5 中的图像 2,2
      • Knot the main string after you have secured all the main strings.
      • Release the tension rod and cut off the remaining string.
      询问修复机器人
      添加评论
    6. How to String a Tennis Racket, Horizontal cross strings: 步骤 6 中的图像 1,1
      • Insert the horizontal cross strings from the left to the right and back to the left.
      • Secure and tighten the end of the string by attaching it to the clamp and moving the rod into the vertical position.
      • Continue threading the cross strings and clamping the strings until all holes have been strung by applying the stringing pattern.
      • Weave the cross strings by going over and under repeatedly through the main strings.
      询问修复机器人
      添加评论
    7. How to String a Tennis Racket, Knot all the cross strings: 步骤 7 中的图像 1,1
      • Knot all of the cross strings after you have secured them.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Tzu-Wei
于09/19/20注册
153 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 54
总计 5,644
