跳转到主内容
加入维修社区 - 创建账户
How to Splice Wire
你所需要的
  1. How to Splice Wire, Prepare your work area: 步骤 1 中的图像 1,2 How to Splice Wire, Prepare your work area: 步骤 1 中的图像 2,2
    • Set your tools down on a clean, non-flammable surface.
    • Ensure that the work area is well-ventilated and clear of anything that can be damaged during soldering.
    • Attach a stripped wire end to each of the helping hands clips, facing the ends towards each other.
    询问修复机器人
    添加评论
  2. How to Splice Wire: 步骤 2 中的图像 1,1
    • Cut a piece of heat-shrink tubing such that it's 10-15 mm longer than one of the exposed wire ends.
    • Slip the heat shrink over one of the wires, making sure to move the heat shrink away from the soldering point as to avoid any burning.
    询问修复机器人
    添加评论
  3. How to Splice Wire, Intermesh the wire strands: 步骤 3 中的图像 1,3 How to Splice Wire, Intermesh the wire strands: 步骤 3 中的图像 2,3 How to Splice Wire, Intermesh the wire strands: 步骤 3 中的图像 3,3
    • This step shows how to physically intermesh stranded wires together. This improves the physical properties of the joined wires.
    • Unravel all of the wire strands for both the wires, intermesh them, and then twist the strands together.
    询问修复机器人
    添加评论
  4. How to Splice Wire, Heat up the wires: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    FixHub Smart Soldering Iron
    $79.95
    • Place the tip of a soldering iron against the exposed wires. You want to heat the wires hot enough such that they'll readily melt the solder.
    • Position the tip such that you maximize the wire surface area it touches.
    询问修复机器人
    添加评论
  5. How to Splice Wire, Apply solder wire: 步骤 5 中的图像 1,2 How to Splice Wire, Apply solder wire: 步骤 5 中的图像 2,2
    • Slowly feed solder wire into the heated wire. The wire strands should readily absorb the molten solder.
    • If the solder pools on top of the wire strands, the strands aren't hot enough to melt the solder. Try moving the soldering iron so that the tip touches more of the strands.
    • Feed solder wire along the exposed wire until everything is thinly coated.
    • Once the molten solder saturates the wire strands, allow the solder joint to cool down and solidify (2-3 minutes).
    询问修复机器人
    添加评论
  6. How to Splice Wire, Cover the exposed solder joint: 步骤 6 中的图像 1,3 How to Splice Wire, Cover the exposed solder joint: 步骤 6 中的图像 2,3 How to Splice Wire, Cover the exposed solder joint: 步骤 6 中的图像 3,3
    • Slide the heat-shrink over the exposed solder joint so that it completely covers the joint and the surrounding insulation.
    • The heat-shrink acts as insulation for the wire.
    • Wave a heat source (lighter or heat gun) over the heat-shrink material to activate it. Apply heat until the heat-shrink has shrunk securely around the solder joint.
    添加评论
结论
You have successfully soldered two wires together!
For more soldering tips and guides, click here.
取消:我没有完成这个指南。
26等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 47
过去 7 天: 387
过去 30 天: 1,469
总计 29,958
