跳转到主内容
How to Open the Samsung Galaxy Watch5
你所需要的
  1. How to Open the Samsung Galaxy Watch5, Remove the watch band: 步骤 1 中的图像 1,1
    • Take your watch off the charger and power it down.
    • Remove the watch band.
  2. How to Open the Samsung Galaxy Watch5, Unfasten the back cover: 步骤 2 中的图像 1,1
    • Use a Tri-point Y00 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
  3. How to Open the Samsung Galaxy Watch5, Pry the back cover: 步骤 3 中的图像 1,2 How to Open the Samsung Galaxy Watch5, Pry the back cover: 步骤 3 中的图像 2,2
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to loosen the gasket and create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
  4. How to Open the Samsung Galaxy Watch5, Disconnect the sensor flex cable: 步骤 4 中的图像 1,2 How to Open the Samsung Galaxy Watch5, Disconnect the sensor flex cable: 步骤 4 中的图像 2,2
    • Lay the watch screen-side down.
    • Carefully swing open the back cover at the gap you just created.
    • Use a spudger to disconnect the sensor flex cable from the motherboard by prying the press connector straight up from its socket.
    • During reassembly, this is a good point to turn on your device and test your repair before resealing it.
  5. How to Open the Samsung Galaxy Watch5, Remove the back cover: 步骤 5 中的图像 1,2 How to Open the Samsung Galaxy Watch5, Remove the back cover: 步骤 5 中的图像 2,2
    • Remove the back cover.
    • During reassembly:
    • Make sure the rubber gasket (marked in red) is undamaged. If damaged, replace it with a new one to maintain water resistance.
结论
3等其他人完成本指南。
Manuel Haeussermann
于07/13/22注册
22,761 声望
创作了71篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,735篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 25
过去 30 天: 164
总计 4,362
