跳转到主内容
How to Open and Clean a PlayStation 4
你所需要的
  1. How to Open and Clean a PlayStation 4, Flip over the PS4: 步骤 1 中的图像 1,1
    • Flip your PS4 upside-down with the back side facing towards you.
  2. How to Open and Clean a PlayStation 4, Remove the rear stickers: 步骤 2 中的图像 1,3 How to Open and Clean a PlayStation 4, Remove the rear stickers: 步骤 2 中的图像 2,3 How to Open and Clean a PlayStation 4, Remove the rear stickers: 步骤 2 中的图像 3,3
    • Stickers cover the screws securing the PS4's outer case.
    • Use a pair of tweezers to remove the sticker in the center of the back of the PS4, exposing the first screw.
    • Remove the two stickers at the outer edges, exposing two more screws.
  3. How to Open and Clean a PlayStation 4, Remove the rear case screws: 步骤 3 中的图像 1,1
    • Remove the three 7.2 mm-long TR8 Torx security screws on the back of the PS4.
  4. How to Open and Clean a PlayStation 4, Remove the lower case: 步骤 4 中的图像 1,2 How to Open and Clean a PlayStation 4, Remove the lower case: 步骤 4 中的图像 2,2
    • Use your thumbs to lift the lower case up and off the PS4.
    • In addition to the three rear screws, the lower case is held in place by plastic clips. You may need to use significant force to release the lower case.
  5. How to Open and Clean a PlayStation 4, Disconnect the power supply: 步骤 5 中的图像 1,2 How to Open and Clean a PlayStation 4, Disconnect the power supply: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    Small Needle Nose Pliers
    $6.99
    • Use a pair of tweezers to pull the power supply cable straight out to disconnect the power supply unit from the motherboard.
    • Depending on the age of your console, this cable might be very firmly connected. If it feels stuck, don't pull on the cables themselves with much force.
    • Use your fingers to grab the white connector head, and wiggle or "walk" the connector out of its socket to disconnect it.
    • In extreme cases, you might need to use needle nose pliers to get a good grip on the connector.
    • Go slow: pulling on the cables themselves might rip them out of the connector.
  6. How to Open and Clean a PlayStation 4, Remove the power supply unit: 步骤 6 中的图像 1,2 How to Open and Clean a PlayStation 4, Remove the power supply unit: 步骤 6 中的图像 2,2
    • Remove three 9.7 mm-long TR8 Torx security screws.
    • Remove two 41 mm-long Phillips screws and brackets.
  7. How to Open and Clean a PlayStation 4: 步骤 7 中的图像 1,3 How to Open and Clean a PlayStation 4: 步骤 7 中的图像 2,3 How to Open and Clean a PlayStation 4: 步骤 7 中的图像 3,3
    • Lift the power supply straight up and out of the PS4.
    • The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to remove it.
    • During reassembly, ensure the prongs are aligned, then press the power supply into place.
  8. How to Open and Clean a PlayStation 4, Clean the fan: 步骤 8 中的图像 1,2 How to Open and Clean a PlayStation 4, Clean the fan: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    Dust Blower
    $18.99
    • Over time, dust will build up inside the fan and on the fan blades.
    • Use a pair of tweezers to grab loose hairs and dust clumps off of the fan.
    • Use a small dust blower or light compressed air to blow remaining dust off of the fan.
    • Use a finger to keep the fan blades steady—it makes them easier to clean.
    • If there's a layer of grime on the fan blades, use soapy water or isopropyl alcohol on a cotton swab to wipe them off.
  9. How to Open and Clean a PlayStation 4, Clean the case: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
  10. How to Open and Clean a PlayStation 4, Clean vents and hard-to-reach areas: 步骤 10 中的图像 1,1
    在这个步骤中使用的工具:
    Anti-Static Brush
    $2.99
    • Depending on how dirty your console is, you might need to use a soft bristle brush to dislodge more dust and grime.
    • Using an anti-static brush or a new toothbrush, clean any dust out of hard to reach areas and off of the rear vents.
    • Use a dust blower to blow any loose dust out of the console and a cloth to wipe the vents clean.
  11. How to Open and Clean a PlayStation 4, Clean the heatsink: 步骤 11 中的图像 1,2 How to Open and Clean a PlayStation 4, Clean the heatsink: 步骤 11 中的图像 2,2
    • The PS4 draws air through the heatsink fins, and they may clog with dust and debris over time.
    • If you can see dust buildup in the heatsink, dislodge debris with a brush and use a dust blower to blow it clean.
    • Remember: use this time to clean any other dirty internal surfaces before you seal your console back up. Happy gaming!
结论
Disassembly or cleaning didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 4 Answers community for help.
37等其他人完成本指南。
Carsten Frauenheim
于03/10/20注册
155,893 声望
创作了439篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,752篇指南
3指南评论
Thanks for the help now my ps4 runs quetly you Are a plessing.🙂
Martin1234 - 回复
eu limpei a minha e nao voltou a ligar, o que que eu faço
David Almeida - 回复
quem souber de algo ajude pfvr
David Almeida -
添加评论
浏览统计数据:
过去 24 小时: 173
过去 7 天: 1,310
过去 30 天: 5,290
总计 61,136
