跳转到主内容
How to Install and Remove Expansion Cards
你所需要的
  1. How to Install and Remove Expansion Cards, Set your laptop down: 步骤 1 中的图像 1,1
    • Set your laptop face-down on a clean work surface.
  2. How to Install and Remove Expansion Cards, Install an Expansion Card: 步骤 2 中的图像 1,3 How to Install and Remove Expansion Cards, Install an Expansion Card: 步骤 2 中的图像 2,3 How to Install and Remove Expansion Cards, Install an Expansion Card: 步骤 2 中的图像 3,3
    • The next two steps show how to install an Expansion Card.
    • Slide an Expansion Card into an Expansion Card slot.
    • You don't need to unlock the latches to install the Expansion Cards—only when you want to remove them.
    • The Expansion Cards should click into place, and the front edge should be flush with the laptop.
  3. How to Install and Remove Expansion Cards: 步骤 3 中的图像 1,2 How to Install and Remove Expansion Cards: 步骤 3 中的图像 2,2
    • If there's a red bar showing under the Expansion Card latch, use your finger to flip the latch and lock the Expansion Card into its slot.
    • Locking the Expansion Card slots helps keep the cards in place when you unplug cables from them.
  4. How to Install and Remove Expansion Cards, Remove an Expansion Card: 步骤 4 中的图像 1,2 How to Install and Remove Expansion Cards, Remove an Expansion Card: 步骤 4 中的图像 2,2
    • The next two steps show how to remove an Expansion Card.
    • Use your fingers to flip the two Expansion Card latches (one for each side) into the unlocked position.
    • The latches display a red bar when they're unlocked.
  5. How to Install and Remove Expansion Cards: 步骤 5 中的图像 1,3 How to Install and Remove Expansion Cards: 步骤 5 中的图像 2,3 How to Install and Remove Expansion Cards: 步骤 5 中的图像 3,3
    • Grip the lip of the Expansion Card with your fingers.
    • Pull the Expansion Card out of its slot and remove it.
    • If you have trouble pulling the Expansion Card out, you can also use the flat end of your Framework Screwdriver to push against the lip.
结论
If you need help, contact Framework support.
Arthur Shi
于01/03/18注册
310,341 声望
创作了701篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了15,803篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 31
总计 327
