跳转到主内容
How to Install a Plastic Snap With a Handheld Tool
你所需要的
  1. How to Install a Plastic Snap With a Handheld Tool, Snap information: 步骤 1 中的图像 1,2 How to Install a Plastic Snap With a Handheld Tool, Snap information: 步骤 1 中的图像 2,2
    • A full set of plastic snaps consists of four parts:
    • Two caps
    • One stud
    • One socket
    • When the snap is installed, the socket and stud will lock together, while a cap holds each of them in place from the other side of the fabric.
  2. How to Install a Plastic Snap With a Handheld Tool, Pierce the fabric: 步骤 2 中的图像 1,2 How to Install a Plastic Snap With a Handheld Tool, Pierce the fabric: 步骤 2 中的图像 2,2
    • Push the point of an awl through the fabric to pierce a hole for the snap.
    • It's better to measure twice, pierce once! Piercing the fabric multiple times within a small area will weaken the fabric.
  3. How to Install a Plastic Snap With a Handheld Tool, Install the snap: 步骤 3 中的图像 1,3 How to Install a Plastic Snap With a Handheld Tool, Install the snap: 步骤 3 中的图像 2,3 How to Install a Plastic Snap With a Handheld Tool, Install the snap: 步骤 3 中的图像 3,3
    • Use your fingers to squeeze a cap pin through the fabric hole.
  4. How to Install a Plastic Snap With a Handheld Tool: 步骤 4 中的图像 1,3 How to Install a Plastic Snap With a Handheld Tool: 步骤 4 中的图像 2,3 How to Install a Plastic Snap With a Handheld Tool: 步骤 4 中的图像 3,3
    • Place either a stud or a socket on top of the pin.
    • If you can't see the pin after placing the stud or socket, the fabric is too thick for the snap. You'll need a cap with a longer pin.
  5. How to Install a Plastic Snap With a Handheld Tool: 步骤 5 中的图像 1,2 How to Install a Plastic Snap With a Handheld Tool: 步骤 5 中的图像 2,2
    • Make sure the snap is facing the correct side for the clothing item.
    • Center the snap components in the fastener tool. The cap should sit fully in the black die cup.
  6. How to Install a Plastic Snap With a Handheld Tool: 步骤 6 中的图像 1,3 How to Install a Plastic Snap With a Handheld Tool: 步骤 6 中的图像 2,3 How to Install a Plastic Snap With a Handheld Tool: 步骤 6 中的图像 3,3
    • Firmly squeeze the fastener tool handles. The white rubber head should bulge slightly from the force.
    • Release the handles and remove the tool from the snap.
  7. How to Install a Plastic Snap With a Handheld Tool, Check the new snap: 步骤 7 中的图像 1,2 How to Install a Plastic Snap With a Handheld Tool, Check the new snap: 步骤 7 中的图像 2,2
    • Visually inspect the snap. The center pin should be evenly flattened.
    • Pull on the snap. The snap shouldn't feel loose.
    • If the pin isn't evenly flattened or the snap feels loose, use the fastener tool to compress the snap again. If that doesn't fix it, remove the snap and start again.
  8. How to Install a Plastic Snap With a Handheld Tool, Install the other half of the set: 步骤 8 中的图像 1,3 How to Install a Plastic Snap With a Handheld Tool, Install the other half of the set: 步骤 8 中的图像 2,3 How to Install a Plastic Snap With a Handheld Tool, Install the other half of the set: 步骤 8 中的图像 3,3
    • Repeat the procedure to install the other half of the snap set.
结论
For more clothing repair guides, click here.
2等其他人完成本指南。
Arthur Shi
于01/03/18注册
310,425 声望
创作了701篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,656篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 69
过去 30 天: 268
总计 1,376
