跳转到主内容
How to Install a 2.5" Hard Drive into an External Enclosure
你所需要的
  1. How to Install a 2.5" Hard Drive into an External Enclosure, Install the drive into the enclosure: 步骤 1 中的图像 1,1
    • Before you begin, look at your hard drive's ports and make sure that it has the right connectors:
    • Narrow data port
    • Wide power port
  2. How to Install a 2.5" Hard Drive into an External Enclosure, Open the enclosure: 步骤 2 中的图像 1,1
    • Use the included screwdriver to remove the two Phillips screws.
  3. How to Install a 2.5" Hard Drive into an External Enclosure: 步骤 3 中的图像 1,2 How to Install a 2.5" Hard Drive into an External Enclosure: 步骤 3 中的图像 2,2
    • Slide the plastic tray out of the aluminum housing.
  4. How to Install a 2.5" Hard Drive into an External Enclosure, Install the SSD: 步骤 4 中的图像 1,3 How to Install a 2.5" Hard Drive into an External Enclosure, Install the SSD: 步骤 4 中的图像 2,3 How to Install a 2.5" Hard Drive into an External Enclosure, Install the SSD: 步骤 4 中的图像 3,3
    • Set the drive in the plastic tray and align the drive ports with the tray socket.
    • To prevent strain on the enclosure socket, lay the drive as flat against the tray as possible.
    • Carefully push the drive into the tray socket to seat the ports.
    • Press the drive's raised edge down into the plastic tray.
    • If the drive edge catches on the foam block, the drive is not fully seated against the tray socket. Continue pressing the drive into the socket until it clears the foam block.
  5. How to Install a 2.5" Hard Drive into an External Enclosure: 步骤 5 中的图像 1,1
    • Flip the drive tray over.
    • Use the a Phillips screwdriver to install the four mounting screws (included in the kit) to secure the drive to the tray.
  6. How to Install a 2.5" Hard Drive into an External Enclosure: 步骤 6 中的图像 1,3 How to Install a 2.5" Hard Drive into an External Enclosure: 步骤 6 中的图像 2,3 How to Install a 2.5" Hard Drive into an External Enclosure: 步骤 6 中的图像 3,3
    • Slide the tray back into the aluminum housing.
    • Reinstall the two Phillips screws to secure the tray.
结论
Your drive is ready for use!
48等其他人完成本指南。
Arthur Shi
于01/03/18注册
258,868 声望
创作了531篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,058篇指南
8条评论
You will need to plug the enclosure into a computer to access it. From there, you can format the drive or retrieve data.
Arthur Shi -
How do I plug the enclosure into a computer? Are there cables? Thank you.
Shannon Mikus - 回复
Very good explanation on "How to do it yourself"
Jawa Herath - 回复
Very good Instructions with clear explanations.
Jawa Herath - 回复
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 106
过去 30 天: 473
总计 32,301
