跳转到主内容
加入维修社区 - 创建账户
How to Install Ubuntu Linux
你所需要的
    1. How to Install Ubuntu Linux, Download Ubuntu: 步骤 1 中的图像 1,1
      询问修复机器人
      添加评论
    2. How to Install Ubuntu Linux, Burn to Disk: 步骤 2 中的图像 1,2 How to Install Ubuntu Linux, Burn to Disk: 步骤 2 中的图像 2,2
      • Use disk burning software like ImgBurn to burn Ubuntu to a DVD, or you can use a USB flash drive instead. If you use a flash drive, download UNetbootin and create your installation media.
      • You do not need to burn Ubuntu to a disk if you are using a virtual machine.
      询问修复机器人
      添加评论
    3. How to Install Ubuntu Linux, Boot to installation media: 步骤 3 中的图像 1,1
      • I recommend trying Ubuntu in a virtual machine, which is what I did.
      • If you are using a real computer, you may need to configure the BIOS or press a key on system startup. If you need to change the BIOS settings, set any Optical Drives or USB CD-ROM drives as the first boot priority.
      • If you want to use a virtual machine, set CD/DVD as the first boot priority and mount the iso file to the machine. There is plenty of virtualization software out there, like VirtualBox.
      • If you have successfully booted into the installation media, you will see this picture.
      • Click on the big "Install Ubuntu" button.
      询问修复机器人
      添加评论
    4. How to Install Ubuntu Linux, Install Ubuntu: 步骤 4 中的图像 1,1
      • After a screen asking about additional software, you will asked what you would like to do with your hard disk.
      • If the installer refers to any sort of dual-booting, you must quit the installer and make unallocated space on your hard disk somehow. (See warning for info.)
      • If you are experienced with partitions, you may use this partition editor.
      • If you decide to use the partition editor, please be very careful. Partitions made with this partition editor can cause any other operating systems to become inaccessible.
      询问修复机器人
      添加评论
结论
That's it! Now you can try Ubuntu all you want.
取消:我没有完成这个指南。
7等其他人完成本指南。
Thomas Sirack
于07/25/15注册
561 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 28
总计 1,572
