跳转到主内容
加入维修社区 - 创建账户
How to Install LED License Plate Lights
你所需要的
    1. How to Install LED License Plate Lights, Prep work: 步骤 1 中的图像 1,1
      • You can choose to raise your car with a car lift jack to get better access to the license plate area. This is not absolutely necessary, but will make installation easier.
      询问修复机器人
      添加评论
    2. How to Install LED License Plate Lights, Removing the stock bulb: 步骤 2 中的图像 1,3 How to Install LED License Plate Lights, Removing the stock bulb: 步骤 2 中的图像 2,3 How to Install LED License Plate Lights, Removing the stock bulb: 步骤 2 中的图像 3,3
      • Pull out the license plate lamp assembly and remove the stock license plate bulb.
      询问修复机器人
      添加评论
    3. How to Install LED License Plate Lights, Installing the LED license plate bulb: 步骤 3 中的图像 1,2 How to Install LED License Plate Lights, Installing the LED license plate bulb: 步骤 3 中的图像 2,2
      • Install back the new LED license plate bulb.
      • Test to make sure the LED bulb works.
      询问修复机器人
      添加评论
    4. How to Install LED License Plate Lights, Putting the license plate assembly back: 步骤 4 中的图像 1,2 How to Install LED License Plate Lights, Putting the license plate assembly back: 步骤 4 中的图像 2,2
      • Put the license plate assembly back and repeat on the other side.
      询问修复机器人
      添加评论
    5. How to Install LED License Plate Lights, Enjoy: 步骤 5 中的图像 1,1
      • Once everything works, you can enjoy your new LED license plate look.
      询问修复机器人
      添加评论
结论
See how easy installing these LED license plate lights are? It's almost unbelievable how a quick and simple installation could make such a difference.
取消:我没有完成这个指南。
6等其他人完成本指南。
Eric Wu
于01/21/15注册
3,600 声望
创作了23篇指南
2指南评论
Why do all your pics have such obnoxious watermarks? If the pics are specifically for iFixit.com I would remove the watermarks.
David Spalding - 回复 分享
Good information!
limoh - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 32
过去 30 天: 146
总计 17,635
