跳转到主内容
加入维修社区 - 创建账户
How to Fix a Mirror Frame
你所需要的
  1. How to Fix a Mirror Frame, How to Fix a Mirror Frame: 步骤 1 中的图像 1,1
    • Gather all your broken frame pieces and gently clean off any dust or debris. Once the pieces are clean, arrange them to determine how they fit back into the damaged section. This will help you understand the order in which they need to be glued.
    询问修复机器人
    添加评论
  2. How to Fix a Mirror Frame: 步骤 2 中的图像 1,1
    • Once the pieces are arranged, apply a small amount of Gorilla Glue to the edges that need to be reattached. Press each piece firmly into place. Work slowly to make sure each section aligns with the original shape of the frame.
    • Caution: Gorilla Glue expands as it dries. Use sparingly to prevent overflow onto the visible surface.
    询问修复机器人
    添加评论
  3. How to Fix a Mirror Frame: 步骤 3 中的图像 1,1
    • Use tension bands (rubber bands or elastic straps) to hold the pieces tightly together while the glue cures. Place the bands so that they apply gentle, even pressure across the repaired area without pressing against the mirror glass. Let the glue dry according to the instructions on the adhesive bottle.
    询问修复机器人
    添加评论
  4. How to Fix a Mirror Frame: 步骤 4 中的图像 1,2 How to Fix a Mirror Frame: 步骤 4 中的图像 2,2
    • Once the glue is fully dry, check for any gaps or visible seams between the pieces. Use clay or wood filler to fill in the gaps to create a smooth, continuous surface. Shape the filler to match the pattern and curves of the existing frame. Allow the filler to dry completely before moving on.
    询问修复机器人
    添加评论
  5. How to Fix a Mirror Frame: 步骤 5 中的图像 1,2 How to Fix a Mirror Frame: 步骤 5 中的图像 2,2
    • After the filler has dried, mix your paint to match the color and finish of the frame. Use a small brush or sponge to apply the paint to the repaired areas. Blend it carefully so it matches the rest of the frame. Allow the paint to dry fully before handling.
    询问修复机器人
    添加评论
  6. How to Fix a Mirror Frame: 步骤 6 中的图像 1,1
    • Let the repaired mirror frame dry for 24 hours. Once everything is set, your mirror should be fully restored and ready to use again.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
Regina Bolanos
于06/11/25注册
133 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 100
总计 841
