跳转到主内容
How to Fix Logitech G403 Double Click Issue
你所需要的
  1. How to Fix Logitech G403 Double Click Issue, How to Fix Logitech G403 Double Click Issue: 步骤 1 中的图像 1,1
    • Use a prying tool or your hand to take out both sides of the mouse feet.
  2. How to Fix Logitech G403 Double Click Issue: 步骤 2 中的图像 1,1
    • Use a precision screwdriver to remove four screws from the mouse.
  3. How to Fix Logitech G403 Double Click Issue: 步骤 3 中的图像 1,2 How to Fix Logitech G403 Double Click Issue: 步骤 3 中的图像 2,2
    • Slowly open the mouse, and take care not to tear the ribbon cable.
    • Detach the cable connector.
  4. How to Fix Logitech G403 Double Click Issue: 步骤 4 中的图像 1,2 How to Fix Logitech G403 Double Click Issue: 步骤 4 中的图像 2,2
    • Remove seven screws from the upper cover.
  5. How to Fix Logitech G403 Double Click Issue: 步骤 5 中的图像 1,2 How to Fix Logitech G403 Double Click Issue: 步骤 5 中的图像 2,2
    • Remove four screws from the mouse.
    • Remove the mouse click cover.
  6. How to Fix Logitech G403 Double Click Issue: 步骤 6 中的图像 1,2 How to Fix Logitech G403 Double Click Issue: 步骤 6 中的图像 2,2
    • Remove the five screws attached to the mouse click switches.
  7. How to Fix Logitech G403 Double Click Issue: 步骤 7 中的图像 1,2 How to Fix Logitech G403 Double Click Issue: 步骤 7 中的图像 2,2
    • Open the mouse switch using a prying tool or your hands.
    • Be careful not to lose the white plastic part from the mouse switch.
  8. How to Fix Logitech G403 Double Click Issue: 步骤 8 中的图像 1,2 How to Fix Logitech G403 Double Click Issue: 步骤 8 中的图像 2,2
    • Find the place where more tension is needed.
    • Use a prying tool or your hand to give more tension to the copper piece, making sure the copper is curved.
结论
10等其他人完成本指南。
Jisuk Kang
于07/05/20注册
415 声望
撰写一个指南
团队
10指南评论
step 8 made no sense and had to google it
rel - 回复
did you find a video about that? if you could send it pls or if it was some place where talk more about it
Lian López -
Worked!!! I had this problem for years, even stoped playing valorant bacause of that. Thanks
VampireKing - 回复
I could not open these screws :( What are the screwdriver size to open these?
Siim - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 43
过去 30 天: 413
总计 35,265
