跳转到主内容
加入维修社区 - 创建账户
How to Change to 12V Power Supply
你所需要的
      • Remove the modem so only the open-storm board remains. This is to prevent accidentally frying the modem.
      询问修复机器人
      添加评论
      • Remove the JP1 and JP2 jumpers
      询问修复机器人
      添加评论
      • Plug in the 12V power source
      询问修复机器人
      添加评论
      • Using a multimeter, touch the ground to any of the ground pinouts on the board and measure the JP1 and JP2 jumpers
      • You should see 12V on the middle and bottom pin of JP1 and 12V on the bottom pin of JP2. The top pin of JP2 should be ~ 3.6V
      询问修复机器人
      添加评论
      • If ~ 3.6 V measured on top JP2 jumper, then add jumper in new position.
      • JP2 powers the modem so it's very important that it is not supplied the higher voltage, otherwise the modem will fry.
      询问修复机器人
      添加评论
      • Plug in the 12V power supply again and see if the JP2 jumper measures ~ 3.7V
      询问修复机器人
      添加评论
      • Unplug the power source and plug in the modem.
      • Be vary careful to not skip a modem pin when plugging in and that it is oriented in the correct direction.
      • Power back on the board and wait to see a green light on the modem (indicating that it is properly powered and trying to connect to the internet).
      询问修复机器人
      添加评论
结论
To revert back to 3.7V power, flip back the 2 jumpers to how they were at the start of the guide.
取消:我没有完成这个指南。
Meagan Tobias
于01/29/19注册
154 声望
撰写一个指南
团队
Open-Storm Open-Storm 的会员
Community
14 名成员
创作了49篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 283
