跳转到主内容
How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader
你所需要的
  1. How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader, Remove the old adhesive: 步骤 1 中的图像 1,2 How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader, Remove the old adhesive: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • If you're transferring your power button board to a new screen, skip to this step.
    • Use tweezers, or your fingers, to remove the remaining adhesive at the power button board's spot on the frame.
  2. How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader: 步骤 2 中的图像 1,3 How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader: 步骤 2 中的图像 2,3 How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader: 步骤 2 中的图像 3,3
    • Apply a few drops of isopropyl alcohol (>90%) to the power button board's spot on the frame.
    • Use a spudger to scrape off the adhesive residue.
    • Use a coffee filter or a lint-free cloth to wipe down the spot.
    • Make sure the spot is as clean as possible so the replacement adhesive sits evenly on the frame.
  3. How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader: 步骤 3 中的图像 1,3 How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader: 步骤 3 中的图像 2,3 How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader: 步骤 3 中的图像 3,3
    • Repeat the same adhesive removal procedure for the remaining adhesive at the interconnect cable's spot on the frame.
    • Wait for the frame to dry completely before continuing.
  4. How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader, Apply the power button board adhesive: 步骤 4 中的图像 1,2 How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader, Apply the power button board adhesive: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $2.99
    购买
    • Peel the power button board adhesive strip off its yellow liner to expose the adhesive underneath.
    • If you don't have the pre-cut adhesive strip, you can use a thin double-sided tape like Tesa tape to replace it.
  5. How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader: 步骤 5 中的图像 1,3 How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader: 步骤 5 中的图像 2,3 How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader: 步骤 5 中的图像 3,3
    • Apply the adhesive strip—sticky side down—to its spot on the frame, making sure it's aligned properly around the alignment pegs.
  6. How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader: 步骤 6 中的图像 1,3 How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader: 步骤 6 中的图像 2,3 How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader: 步骤 6 中的图像 3,3
    • Use the flat end of a spudger, or your finger, to press down the adhesive strip and adhere it.
    • Peel off the white liner to expose the top adhesive.
  7. How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader, Apply the interconnect cable adhesive: 步骤 7 中的图像 1,3 How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader, Apply the interconnect cable adhesive: 步骤 7 中的图像 2,3 How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader, Apply the interconnect cable adhesive: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $2.99
    购买
    • Repeat the same adhesive application procedure for the interconnect cable adhesive strip.
  8. How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader, Secure the power button board: 步骤 8 中的图像 1,3 How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader, Secure the power button board: 步骤 8 中的图像 2,3 How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader, Secure the power button board: 步骤 8 中的图像 3,3
    • Reconnect the interconnect cable to the power button board.
    • Place the power button board on its spot on the frame, making sure it sits properly on its alignment pegs.
    • Use the flat end of a spudger, or your finger, to press down the power button board and adhere it.
  9. How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader: 步骤 9 中的图像 1,2 How to Apply the Power Button Board and Interconnect Cable Adhesive in your Kobo Libra Colour eReader: 步骤 9 中的图像 2,2
    • Reconnect the interconnect cable to the motherboard.
    • Use your finger to press the cable onto its adhesive and adhere it to the frame.
    • Return to the original guide and continue reassembly, skipping steps you did for this procedure.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
于01/16/22注册
129,318 声望
创作了600篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,077篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 200
