跳转到主内容
How to Apply Liquid Metal in a PlayStation 5
你所需要的
  1. How to Apply Liquid Metal in a PlayStation 5, Remove the stand screw: 步骤 1 中的图像 1,1
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. How to Apply Liquid Metal in a PlayStation 5, Remove the vertical stand: 步骤 2 中的图像 1,2 How to Apply Liquid Metal in a PlayStation 5, Remove the vertical stand: 步骤 2 中的图像 2,2
    • Lift straight up to remove the stand.
  3. How to Apply Liquid Metal in a PlayStation 5, Store the stand screw: 步骤 3 中的图像 1,2 How to Apply Liquid Metal in a PlayStation 5, Store the stand screw: 步骤 3 中的图像 2,2
    • Insert the screw into the cubby on the bottom of the stand.
  4. How to Apply Liquid Metal in a PlayStation 5, Cap the screw hole: 步骤 4 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5, Cap the screw hole: 步骤 4 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5, Cap the screw hole: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. How to Apply Liquid Metal in a PlayStation 5, Close the cubby: 步骤 5 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5, Close the cubby: 步骤 5 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5, Close the cubby: 步骤 5 中的图像 3,3
    • Twist the stand counterclockwise to close the cubby.
  6. How to Apply Liquid Metal in a PlayStation 5, Remove the horizontal stand: 步骤 6 中的图像 1,2 How to Apply Liquid Metal in a PlayStation 5, Remove the horizontal stand: 步骤 6 中的图像 2,2
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
  7. How to Apply Liquid Metal in a PlayStation 5, Remove the right faceplate: 步骤 7 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5, Remove the right faceplate: 步骤 7 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5, Remove the right faceplate: 步骤 7 中的图像 3,3
    • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
    • Lift up the corner of the faceplate to unclip it from the case.
  8. How to Apply Liquid Metal in a PlayStation 5: 步骤 8 中的图像 1,2 How to Apply Liquid Metal in a PlayStation 5: 步骤 8 中的图像 2,2
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the right faceplate.
  9. How to Apply Liquid Metal in a PlayStation 5, Pry up the grille: 步骤 9 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5, Pry up the grille: 步骤 9 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5, Pry up the grille: 步骤 9 中的图像 3,3
    • Insert the flat end of a spudger underneath the grille and into the gap above the fan.
    • Lift up with the spudger to pry the grille away from the case.
  10. How to Apply Liquid Metal in a PlayStation 5, Remove the grille: 步骤 10 中的图像 1,2 How to Apply Liquid Metal in a PlayStation 5, Remove the grille: 步骤 10 中的图像 2,2
    • Lift the grille away from the case to remove it.
  11. How to Apply Liquid Metal in a PlayStation 5, Remove the fan shroud screws: 步骤 11 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $16.96
    • Use a T9 Torx Security driver to remove the four screws securing the fan shroud to the case:
    • Two 23.3 mm-long screws
    • One 11.4 mm-long screw
    • One 31 mm-long screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  12. How to Apply Liquid Metal in a PlayStation 5, Remove the fan shroud: 步骤 12 中的图像 1,2 How to Apply Liquid Metal in a PlayStation 5, Remove the fan shroud: 步骤 12 中的图像 2,2
    • Lift the fan shroud straight up to remove it.
  13. How to Apply Liquid Metal in a PlayStation 5, Remove the wire cover: 步骤 13 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5, Remove the wire cover: 步骤 13 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5, Remove the wire cover: 步骤 13 中的图像 3,3
    • Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
    • Pry only on the wire cover, not on the fan wires themselves.
    • Use the spudger to peel up the wire cover until you can grip it with your fingers.
  14. How to Apply Liquid Metal in a PlayStation 5: 步骤 14 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5: 步骤 14 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5: 步骤 14 中的图像 3,3
    • Use your fingers to peel off the wire cover.
  15. How to Apply Liquid Metal in a PlayStation 5, Disconnect the fan: 步骤 15 中的图像 1,2 How to Apply Liquid Metal in a PlayStation 5, Disconnect the fan: 步骤 15 中的图像 2,2
    • Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
    • Always pull cables by their connectors and not the wires themselves.
  16. How to Apply Liquid Metal in a PlayStation 5, Remove the fan: 步骤 16 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5, Remove the fan: 步骤 16 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5, Remove the fan: 步骤 16 中的图像 3,3
    • Lift the fan up and out of the case to remove it.
  17. How to Apply Liquid Metal in a PlayStation 5, Remove the SSD cover: 步骤 17 中的图像 1,1
    • Use a Phillips screwdriver to remove the 17 mm-long SSD cover screw.
  18. How to Apply Liquid Metal in a PlayStation 5: 步骤 18 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5: 步骤 18 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5: 步骤 18 中的图像 3,3
    • Use your finger to slide the SSD cover towards the top of the device to unclip it from the case.
    • Remove the SSD cover.
  19. How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive wire: 步骤 19 中的图像 1,2 How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive wire: 步骤 19 中的图像 2,2
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the motherboard.
  20. How to Apply Liquid Metal in a PlayStation 5: 步骤 20 中的图像 1,2 How to Apply Liquid Metal in a PlayStation 5: 步骤 20 中的图像 2,2
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the optical drive.
  21. How to Apply Liquid Metal in a PlayStation 5, Remove the tamper-evident sticker: 步骤 21 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5, Remove the tamper-evident sticker: 步骤 21 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5, Remove the tamper-evident sticker: 步骤 21 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the tamper-evident sticker covering the remaining case screw.
    • If your PlayStation 5 hasn't been opened before, this sticker will be completely black. The pattern will appear after you remove it.
    • Technically, these are tamper-evident stickers—but don't worry—Sony can't legally void your warranty, as long as you don't damage anything. Have fun!
  22. How to Apply Liquid Metal in a PlayStation 5, Remove the case screws: 步骤 22 中的图像 1,1
    • Use a T8 Torx driver to remove the eleven screws securing the case:
    • Six 18.6 mm-long screws
    • Two 43.2 mm-long screws
    • One 7.3 mm-long screw
  23. How to Apply Liquid Metal in a PlayStation 5, Remove the case: 步骤 23 中的图像 1,2 How to Apply Liquid Metal in a PlayStation 5, Remove the case: 步骤 23 中的图像 2,2
    • Lift the case straight up to remove it.
  24. How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive ribbon cable: 步骤 24 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive ribbon cable: 步骤 24 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive ribbon cable: 步骤 24 中的图像 3,3
    • Use the flat end of a spudger to press down on the optical drive connector's metal locking tab.
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the optical drive.
    • Pull only on the pull tab, not the cable itself.
  25. How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive: 步骤 25 中的图像 1,2 How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive: 步骤 25 中的图像 2,2
    • Lift the optical drive away from the device to remove it.
  26. How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive ribbon cable: 步骤 26 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive ribbon cable: 步骤 26 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive ribbon cable: 步骤 26 中的图像 3,3
    在这个步骤中使用的工具:
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the motherboard.
  27. How to Apply Liquid Metal in a PlayStation 5, Remove the power and eject button ribbon cable: 步骤 27 中的图像 1,2 How to Apply Liquid Metal in a PlayStation 5, Remove the power and eject button ribbon cable: 步骤 27 中的图像 2,2
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the power and eject button ribbon cable.
  28. How to Apply Liquid Metal in a PlayStation 5, Remove the LED ribbon cable: 步骤 28 中的图像 1,2 How to Apply Liquid Metal in a PlayStation 5, Remove the LED ribbon cable: 步骤 28 中的图像 2,2
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the LED ribbon cable.
  29. How to Apply Liquid Metal in a PlayStation 5, Remove the antenna wires: 步骤 29 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5, Remove the antenna wires: 步骤 29 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5, Remove the antenna wires: 步骤 29 中的图像 3,3
    • Use a pair of tweezers to grip the white Wi-Fi antenna wire at its metal base, as close to the connector as possible.
    • Lift the wire's connector straight up to disconnect it from the motherboard.
    • Repeat for the black Wi-Fi antenna wire.
    • Some board revisions may not have these antenna wires. If your board is missing these connectors, skip this step.
  30. How to Apply Liquid Metal in a PlayStation 5: 步骤 30 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5: 步骤 30 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5: 步骤 30 中的图像 3,3
    • Use a pair of tweezers to grip the black or blue power supply antenna wire at its metal base, as close to the connector as possible.
    • Repeat for the white power supply antenna wire.
  31. How to Apply Liquid Metal in a PlayStation 5, Remove the white stickers: 步骤 31 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5, Remove the white stickers: 步骤 31 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5, Remove the white stickers: 步骤 31 中的图像 3,3
    • Use a pair of tweezers to peel back the white sticker holding the antenna wires to the top shield plate.
    • Remove the antenna wires from underneath the sticker.
    • Press the white sticker back down onto the top shield plate so it can be reused.
  32. How to Apply Liquid Metal in a PlayStation 5: 步骤 32 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5: 步骤 32 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5: 步骤 32 中的图像 3,3
    • Repeat the previous step to peel back the four remaining stickers.
  33. How to Apply Liquid Metal in a PlayStation 5: 步骤 33 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5: 步骤 33 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5: 步骤 33 中的图像 3,3
    • Use a pair of tweezers to peel back the white sticker holding the LED ribbon cable to the heat sink.
    • Remove the LED ribbon cable from underneath the sticker.
    • Press the white sticker back down onto the heat sink so it can be reused.
  34. How to Apply Liquid Metal in a PlayStation 5, Remove the top shield plate screws: 步骤 34 中的图像 1,1
    • Use a T8 Torx driver to remove the forty-two screws securing the top shield plate:
    • Forty-one 7.3 mm-long screws
    • One 43.2 mm-long screw
  35. How to Apply Liquid Metal in a PlayStation 5, Remove the top shield plate: 步骤 35 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5, Remove the top shield plate: 步骤 35 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5, Remove the top shield plate: 步骤 35 中的图像 3,3
    • Lift the top shield plate off of the motherboard to remove it.
    • During reassembly, this is a good point to replace any thermal pads on the top of the main board, if necessary. The pads may be stuck to both the top shield plate and the main board.
    • It's important that the replacement pads are the same thickness as the originals, otherwise the foam around the APU may not seal properly.
  36. How to Apply Liquid Metal in a PlayStation 5, Disconnect the USB board: 步骤 36 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5, Disconnect the USB board: 步骤 36 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5, Disconnect the USB board: 步骤 36 中的图像 3,3
    • Use your finger to depress the metal locking tab on the USB board cable's board connector.
    • With the metal tab depressed, place the flat end of a spudger against the insulating foam pad on the ribbon cable and pull it directly away from the connector to disconnect it.
  37. How to Apply Liquid Metal in a PlayStation 5, Remove the main board screws: 步骤 37 中的图像 1,2 How to Apply Liquid Metal in a PlayStation 5, Remove the main board screws: 步骤 37 中的图像 2,2
    • Use a Phillips screwdriver to remove the 11 mm‑long SSD screw.
    • Be careful not to lose the small spacer under the screw.
    • Use a Phillips screwdriver to remove the two 11.8 mm‑long APU tension bracket screws.
    • Don't remove or install one screw at a time, or you may damage the APU. During disassembly and reassembly, alternate between the two screws a 1/2 turn at a time to maintain even pressure on the bracket.
    • Use a TR8 Torx security screwdriver to remove the two remaining 7.3 mm‑long main board screws.
  38. How to Apply Liquid Metal in a PlayStation 5: 步骤 38 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5: 步骤 38 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5: 步骤 38 中的图像 3,3
    • Lift and remove both APU brackets from the board.
    • During reassembly:
    • Put the bracket with plastic arms on first so the pegs go into their cutouts.
    • Then, put the metal bracket onto the plastic one so they're perpendicular and the screw holes line up.
  39. How to Apply Liquid Metal in a PlayStation 5, Separate the main board: 步骤 39 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5, Separate the main board: 步骤 39 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5, Separate the main board: 步骤 39 中的图像 3,3
    • Don't try to fully remove the motherboard during this step—the corner near the power button is still secured by metal prongs, which will be disconnected in the next step.
    • Gently lift the edge of the motherboard with the large cutout to partially separate it from the bottom shield plate.
    • With the board lifted, insert the flat end of a spudger between the board and the bottom shield plate and gently twist to separate them. Work your way around the perimeter of the board.
    • Many small thermal pads bond the main board to the metal shield plate underneath. Depending on the age of your PlayStation and the condition of the pads, it may take significant force to separate the board.
  40. How to Apply Liquid Metal in a PlayStation 5: 步骤 40 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5: 步骤 40 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5: 步骤 40 中的图像 3,3
    • The power supply is connected to the bottom of the main board assembly by metal prongs that plug into the bottom left corner.
    • Insert the flat end of a spudger between the board and the lower shield plate, by the two parallel solder joints near the corner with the power button.
    • Twist the spudger to lift the two prongs under the board out of their socket.
    • You should feel the prongs slide out.
    • During reassembly, press down on the corner of the board to fully seat the prongs in the power supply—you should feel them slide into place.
  41. How to Apply Liquid Metal in a PlayStation 5, Remove the main board: 步骤 41 中的图像 1,2 How to Apply Liquid Metal in a PlayStation 5, Remove the main board: 步骤 41 中的图像 2,2
    • Remove the main board, flip it over, and carefully lay it on a clean work surface, so the APU is facing up.
    • Don't press the board against your work surface, or you may damage fragile components.
    • Make sure all cables that connect to the board are out of the way so they don't get trapped underneath.
    • Carefully flip the board over so the APU is on the bottom, making sure no liquid metal spills.
    • Keep the board level and lower it into place.
  42. How to Apply Liquid Metal in a PlayStation 5, Remove the old liquid metal from the heatsink: 步骤 42 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5, Remove the old liquid metal from the heatsink: 步骤 42 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5, Remove the old liquid metal from the heatsink: 步骤 42 中的图像 3,3
    在这个步骤中使用的工具:
    Dispensing Syringe Kit 9 pieces
    $8.99
    • Wear gloves to protect your skin from the liquid metal.
    • If you have a disposable syringe, you can use it to suck up any large pools of liquid metal. Don't use the syringe containing your new liquid metal.
    • Starting with the heatsink: apply a few drops of highly-concentrated (greater than 90%) isopropyl alcohol to a cotton swab and carefully clean up all of the liquid metal from the heatsink surface.
    • Removing the liquid metal can be tricky—it spreads and smears easily. Switch to new cotton swabs and apply more alcohol as necessary.
    • Use the same cleaning process to thoroughly clean up all of the liquid metal residue.
    • The surface needs to be completely clean for the new liquid metal to work properly.
    • Let the heatsink dry completely.
  43. How to Apply Liquid Metal in a PlayStation 5, Remove the old liquid metal from the APU: 步骤 43 中的图像 1,2 How to Apply Liquid Metal in a PlayStation 5, Remove the old liquid metal from the APU: 步骤 43 中的图像 2,2
    • Don't remove the foam barrier that surrounds the APU.
    • Just as you did for the heatsink, clean and remove all of the old liquid metal and its residue from the APU.
    • Don't let any of the liquid metal drip onto the board. Liquid metal is conductive and could cause a short. The foam barrier keeps the liquid metal from leaking out.
    • This is a good point to replace any thermal pads on the bottom of the main board, if necessary. The pads might be stuck to both the bottom shield plate and the main board.
    • Make sure your replacement pads are the same thickness as the originals, or the foam around the APU may not seal properly.
  44. How to Apply Liquid Metal in a PlayStation 5, Apply new liquid metal: 步骤 44 中的图像 1,3 How to Apply Liquid Metal in a PlayStation 5, Apply new liquid metal: 步骤 44 中的图像 2,3 How to Apply Liquid Metal in a PlayStation 5, Apply new liquid metal: 步骤 44 中的图像 3,3
    • Apply a small drop of liquid metal to the heatsink (not the APU)—about the size of a small matchstick head.
    • If your liquid metal syringe has multiple applicator heads, use the one with a small, needle-like tip.
    • Use the spreader that came with your liquid metal or a new cotton swab to lightly push down on and evenly spread the liquid metal across the entire surface.
    • If there's excess liquid metal anywhere, use the syringe to suck it back up.
  45. How to Apply Liquid Metal in a PlayStation 5: 步骤 45 中的图像 1,2 How to Apply Liquid Metal in a PlayStation 5: 步骤 45 中的图像 2,2
    • Your cotton swab from the previous step should still have some liquid metal left on it.
    • Use the same cotton swab to spread a thin layer of liquid metal evenly onto the APU. If you need more liquid metal, lightly dab the cotton swab on the heatsink to transfer some, or apply a very small drop from the syringe.
    • The main board is now ready for reassembly.
结论
To reassemble your device, follow these instructions in reverse order, starting with this step.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
16等其他人完成本指南。
Spencer Day
于09/14/22注册
148,862 声望
创作了995篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,589篇指南
2指南评论
Una domanda se posso:
Come mai su tutti i video tutorial spargono il metallo liquido sia sul dissipatore che sull'apu?
Quanti gr di liquido metallico necessitano in totale?
Tonynox - 回复
J'ai effectué le grand nettoyage de ma console PlayStation 5 1ère génération version Disque.
J'ai effectué également le changement du liquide métal, que j'ai acheté sur Amazon (1gr).
C'était plus facile de démonter que de remonter...
Par contre sur l'étape 37 je n'ai pas les mêmes vis, il faut sur ma console les enlevées par l'arrière de la protection noir (socle), 2 vis.
Sinon tout est ok, j'ai mis environ 2 heures, c'est la 1ère fois que je fais ça.
Pour étaler le liquide métal, ce n'est pas facile, j'ai un peu galérer...
Et je n'ai pas réussi a nettoyer correctement la base, il y avait des morceaux qui ne s'enlevaient pas.
En tout cas merci du partage, le tutorial est super, c'est un excellent travail.
J'ai quand même une grande colère envers Sony pour avoir vendu une console aussi chère pour une qualité aussi pourrie...
Enfin bon ! Merci !
(J'ai oublié de dire que ma console était toujours à la verticale, le liquide a coulé, cela se voyait... Maintenant elle est a l'horizontale :)
Merci
Ludwin L - 回复
添加评论
浏览统计数据:
过去 24 小时: 126
过去 7 天: 933
过去 30 天: 3,994
总计 58,487
