跳转到主内容
加入维修社区 - 创建账户
How to Access the Internal Components of an HP 15-R011DX
你所需要的
    1. How to Access the Internal Components of an HP 15-R011DX, Battery: 步骤 1 中的图像 1,2 How to Access the Internal Components of an HP 15-R011DX, Battery: 步骤 1 中的图像 2,2
      • Slide the lock mechanism on the left side of the laptop to the right.
      询问修复机器人
      添加评论
    2. How to Access the Internal Components of an HP 15-R011DX: 步骤 2 中的图像 1,1
      • While holding the right slide mechanism, remove the battery from the laptop.
      • The battery is not pictured here because it is missing from this particular device.
      询问修复机器人
      添加评论
    1. How to Access the Internal Components of an HP 15-R011DX, How to Access the Internal Components of an HP 15-R011DX: 步骤 3 中的图像 1,2 How to Access the Internal Components of an HP 15-R011DX, How to Access the Internal Components of an HP 15-R011DX: 步骤 3 中的图像 2,2
      • Flip the laptop over to reveal screw locations.
      • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
      询问修复机器人
      添加评论
    2. How to Access the Internal Components of an HP 15-R011DX: 步骤 4 中的图像 1,2 How to Access the Internal Components of an HP 15-R011DX: 步骤 4 中的图像 2,2
      • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
      询问修复机器人
      添加评论
    3. How to Access the Internal Components of an HP 15-R011DX: 步骤 5 中的图像 1,2 How to Access the Internal Components of an HP 15-R011DX: 步骤 5 中的图像 2,2
      • Remove the DVD drive from the laptop.
      • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
      添加评论
    4. How to Access the Internal Components of an HP 15-R011DX: 步骤 6 中的图像 1,3 How to Access the Internal Components of an HP 15-R011DX: 步骤 6 中的图像 2,3 How to Access the Internal Components of an HP 15-R011DX: 步骤 6 中的图像 3,3
      • Flip the laptop and open.
      • Detach the keyboard by prying it free from the laptop using a spudger.
      • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
      • Disconnect the keyboard ribbon cable.
      询问修复机器人
      添加评论
    5. How to Access the Internal Components of an HP 15-R011DX: 步骤 7 中的图像 1,2 How to Access the Internal Components of an HP 15-R011DX: 步骤 7 中的图像 2,2
      • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
      • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
      • Pry open the plastic casing using a spudger.
      • If struggling to remove the plastic case, check that all screws have been removed.
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
UMass Dartmouth, Team S2-G4, Bailey Spring 2019 UMass Dartmouth, Team S2-G4, Bailey Spring 2019 的会员
UMASSD-BAILEY-S19S2G4
3 名成员
创作了54篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 16
总计 823
