跳转到主内容
加入维修社区 - 创建账户
How to Access GE Washing Machine Error Code Mode
视频指南
本指南转录自 YouTube 视频。
      • Unplug the washing machine for about five minutes and then reconnect power.
      • Ensure the display is blank and no cycle is running before proceeding.
      询问修复机器人
      添加评论
      • Press and hold the Start/Pause button for 10 seconds until the display lights up.
      • Release the button when the first stored code appears.
      询问修复机器人
      添加评论
      • Press Start/Pause again to cycle through each stored error code.
      • Two horizontal lines on the display mean you have reached the end of the list.
      询问修复机器人
      添加评论
      • Press any button on the right side of the control panel except Start or Power.
      • Confirm the display shuts down and the washer exits error code mode.
      询问修复机器人
      添加评论
      • Compare the code on the display with GE's fault list.
      • Use that code to focus your troubleshooting before replacing parts.
      询问修复机器人
      添加评论
      • Press and hold the Start button while rotating the selector knob 180 degrees counterclockwise.
      • Release Start when the display begins flashing.
      • If you overshoot slightly, return the knob to its starting position and try again.
      询问修复机器人
      添加评论
      • Turn the knob clockwise to increase the test number or counterclockwise to decrease it.
      • Press Start once to begin the selected test.
      • Test 1 returns to the stored error code mode from the earlier steps.
      询问修复机器人
      添加评论
      • Press and hold Start/Pause for 10 seconds to reset the washer.
      • Confirm the display returns to normal operation afterward.
      询问修复机器人
      添加评论
      • Check for alerts such as H2O Supply when water flow is restricted or turned off.
      • Watch for a door alert if the washer does not sense a closed or locked lid.
      • If the spin light blinks, rebalance the load and inspect for out-of-balance conditions.
      • If the display shows Cancelled, close the lid and try again, or power-cycle the washer if needed.
      询问修复机器人
      添加评论
      • Record the stored codes and any service-test results before making repairs.
      • Future models may add more test numbers, but the basic entry steps are usually the same.
      询问修复机器人
      添加评论
结论
Use the stored codes and service tests to narrow the fault before replacing parts. Exit diagnostics when you're done and return the washer to normal operation. Repair didn't go as planned? Ask our Answers community for help.
取消:我没有完成这个指南。
2等其他人完成本指南。
Ben Schlichter
于01/21/25注册
7,128 声望
创作了224篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 34
过去 7 天: 161
过去 30 天: 756
总计 9,743
