跳转到主内容
加入维修社区 - 创建账户
How To Restring a Yo-Yo
你所需要的
    1. How To Restring a Yo-Yo, String: 步骤 1 中的图像 1,1
      • Unscrew one half of the Yo-Yo from the other by twisting them in opposing directions.
      询问修复机器人
      添加评论
    2. How To Restring a Yo-Yo: 步骤 2 中的图像 1,1
      • Analyze the current state of the string.
      • If the string is worn out, you must determine whether or not you want to put it back in place and keep using the Yo-Yo till the string fully breaks or replace the string right away.
      • If the string is damaged beyond repair, then get your new string ready.
      询问修复机器人
      添加评论
    3. How To Restring a Yo-Yo: 步骤 3 中的图像 1,1
      • Find the end of the string that does not have a knot tied around it. This end of the string is the finger hole.
      • We are not interested in this end. You will know you have the right end if you can smoothly run a finger along the string.
      询问修复机器人
      添加评论
    4. How To Restring a Yo-Yo: 步骤 4 中的图像 1,1
      • Pull at the threading, making a hole that is just big enough to fit onto the ball bearing.
      • Avoid creating a hole that is bigger than necessary, it’s good practice to do so.
      询问修复机器人
      添加评论
    5. How To Restring a Yo-Yo: 步骤 5 中的图像 1,1
      • Place the hole over the bearing, allowing the string to rest on the half of the Yo-Yo with the ball bearing.
      询问修复机器人
      添加评论
    6. How To Restring a Yo-Yo: 步骤 6 中的图像 1,1
      • Hold the half with the ball bearing with one hand and gently tug on the string with your other hand.
      • This will ensure that the placement of the string is secure.
      询问修复机器人
      添加评论
    7. How To Restring a Yo-Yo: 步骤 7 中的图像 1,1
      • Screw the halves back together firmly, making sure that they are aligned correctly.
      • You shouldn't make the halves tighter than 'hand-tight'. This is good for you and the Yo-Yo so you won't have much trouble trying to open it up.
      询问修复机器人
      添加评论
    8. How To Restring a Yo-Yo: 步骤 8 中的图像 1,1
      • Wind up your Yo-Yo and try do a trick to ensure that you’ve done a good job in restringing your Yo-Yo. Now you can enjoy your ‘Yo-Yoing’!
      询问修复机器人
      添加评论
结论
After following these steps, you will have successfully restrung your Yo-Yo.
取消:我没有完成这个指南。
3等其他人完成本指南。
1指南评论
nice tutorial
sdsdsds - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 88
总计 6,218
