跳转到主内容
加入维修社区 - 创建账户
How To Remove Rust From Old Tools
你所需要的
    1. How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: 步骤 1 中的图像 1,2 How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: 步骤 1 中的图像 2,2
      • Removing rust generally isn't dangerous, but it's pretty messy.
      • Prepare your workspace by laying out an old towel or shop rag that you won't mind getting dirty.
      • Consider also wearing protective gloves.
      • Place your tool on the towels.
      询问修复机器人
      添加评论
    2. How To Remove Rust From Old Tools: 步骤 2 中的图像 1,2 How To Remove Rust From Old Tools: 步骤 2 中的图像 2,2
      • Spray the rusty areas of the tool with a generous amount of WD-40.
      询问修复机器人
      添加评论
    3. How To Remove Rust From Old Tools: 步骤 3 中的图像 1,3 How To Remove Rust From Old Tools: 步骤 3 中的图像 2,3 How To Remove Rust From Old Tools: 步骤 3 中的图像 3,3
      • Use a scouring pad to thoroughly scrub the tool.
      • It shouldn't take a lot of force—the WD-40 and scouring pad will do most of the work.
      询问修复机器人
      添加评论
    4. How To Remove Rust From Old Tools: 步骤 4 中的图像 1,3 How To Remove Rust From Old Tools: 步骤 4 中的图像 2,3 How To Remove Rust From Old Tools: 步骤 4 中的图像 3,3
      • Use a paper towel to wipe away the excess grime and WD-40.
      询问修复机器人
      添加评论
    5. How To Remove Rust From Old Tools: 步骤 5 中的图像 1,1
      • Continue scouring the tool, adding more WD-40 as needed, until the surface is free of rust.
      • When you finish, your tool may not look brand new—but the surface should now be rust-free and ready for years of continued use.
      添加评论
结论
取消:我没有完成这个指南。
13等其他人完成本指南。
Geoff Wacker
于09/30/13注册
92,905 声望
创作了89篇指南
3指南评论
Apple cider vinegar removes rust well. Try it.
Michael Jucker - 回复 分享
Thank you I have tried vinagar ,rust buster and other sprays and only the WD 40 worked best
Ronald Tyler - 回复 分享
Coca-Cola also works, soak over night
Gil Flores - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 31
过去 30 天: 168
总计 9,211
