跳转到主内容
加入维修社区 - 创建账户
Hover-1 Titan Left Gyroscope Replacement
你所需要的
    1. Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: 步骤 1 中的图像 1,2 Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: 步骤 1 中的图像 2,2
      • Flip the hoverboard so the bottom is facing up.
      • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
      询问修复机器人
      添加评论
    2. Hover-1 Titan Left Gyroscope Replacement: 步骤 2 中的图像 1,2 Hover-1 Titan Left Gyroscope Replacement: 步骤 2 中的图像 2,2
      • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
      • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
      • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
      询问修复机器人
      添加评论
    3. Hover-1 Titan Left Gyroscope Replacement: 步骤 3 中的图像 1,3 Hover-1 Titan Left Gyroscope Replacement: 步骤 3 中的图像 2,3 Hover-1 Titan Left Gyroscope Replacement: 步骤 3 中的图像 3,3
      • Grip the bottom left panel and lift up to remove.
      询问修复机器人
      添加评论
    1. Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: 步骤 4 中的图像 1,2 Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: 步骤 4 中的图像 2,2
      • Unplug the battery from the gyroscope by holding the yellow connector and pulling apart.
      询问修复机器人
      添加评论
    2. Hover-1 Titan Left Gyroscope Replacement: 步骤 5 中的图像 1,3 Hover-1 Titan Left Gyroscope Replacement: 步骤 5 中的图像 2,3 Hover-1 Titan Left Gyroscope Replacement: 步骤 5 中的图像 3,3
      • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
      询问修复机器人
      添加评论
    3. Hover-1 Titan Left Gyroscope Replacement: 步骤 6 中的图像 1,2 Hover-1 Titan Left Gyroscope Replacement: 步骤 6 中的图像 2,2
      • Unplug the bottom right connector by squeezing it and pulling it away from the board.
      询问修复机器人
      添加评论
    4. Hover-1 Titan Left Gyroscope Replacement: 步骤 7 中的图像 1,2 Hover-1 Titan Left Gyroscope Replacement: 步骤 7 中的图像 2,2
      • Unplug the light connector by squeezing it and pulling away from the board.
      询问修复机器人
      添加评论
    5. Hover-1 Titan Left Gyroscope Replacement: 步骤 8 中的图像 1,2 Hover-1 Titan Left Gyroscope Replacement: 步骤 8 中的图像 2,2
      • Unplug the blue and white wires by squeezing the connector and pulling away from the board.
      询问修复机器人
      添加评论
    6. Hover-1 Titan Left Gyroscope Replacement: 步骤 9 中的图像 1,2 Hover-1 Titan Left Gyroscope Replacement: 步骤 9 中的图像 2,2
      • Unplug the small white connector by squeezing it and pulling away from the board.
      询问修复机器人
      添加评论
    7. Hover-1 Titan Left Gyroscope Replacement: 步骤 10 中的图像 1,2 Hover-1 Titan Left Gyroscope Replacement: 步骤 10 中的图像 2,2
      • Unplug the plug in the red connector.
      • The red plug is glued to the board, so this step will require extra force.
      询问修复机器人
      添加评论
    8. Hover-1 Titan Left Gyroscope Replacement: 步骤 11 中的图像 1,2 Hover-1 Titan Left Gyroscope Replacement: 步骤 11 中的图像 2,2
      • Unplug the charging cable connector by squeezing it and pulling it away from the board.
      询问修复机器人
      添加评论
    9. Hover-1 Titan Left Gyroscope Replacement: 步骤 12 中的图像 1,1
      • Cut the cable tie.
      • Unplug the remaining wires.
      • The connectors for the remaining wires are in the rubber covers.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018 的会员
CPSU-WHITE-F18S15G4
4 名成员
创作了10篇指南
2指南评论
I’ve got an active broken on the cover not the one to to speaker the other one. Does anyone know where is terminates. I can’t see where it came from. It can only reach the circuit board or the active of the speaker.
Mark - 回复 分享
Where do you buy the board?
eden11 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 35
总计 1,701
