跳转到主内容
加入维修社区 - 创建账户
Hover-1 H1 LED Headlight Replacement
你所需要的
    1. Hover-1 H1 LED Headlight Replacement, Bottom Shell: 步骤 1 中的图像 1,1
      • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      询问修复机器人
      添加评论
    2. Hover-1 H1 LED Headlight Replacement: 步骤 2 中的图像 1,1
      • Puncture the two black stickers by using the tip of a screwdriver.
      • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      询问修复机器人
      添加评论
    3. Hover-1 H1 LED Headlight Replacement: 步骤 3 中的图像 1,2 Hover-1 H1 LED Headlight Replacement: 步骤 3 中的图像 2,2
      • Lift each side of the bottom shell by pulling up.
      • When lifting the shell, take care to not tear any cables from their connectors.
      询问修复机器人
      添加评论
    4. Hover-1 H1 LED Headlight Replacement: 步骤 4 中的图像 1,1
      • Unplug the battery by pulling gently on both sides of the orange connector.
      询问修复机器人
      添加评论
    1. Hover-1 H1 LED Headlight Replacement, LED Headlights: 步骤 5 中的图像 1,1
      • Unplug the lights from the battery by pulling gently on both sides of the black connector attached to the white wires.
      询问修复机器人
      添加评论
    2. Hover-1 H1 LED Headlight Replacement: 步骤 6 中的图像 1,1
      • Remove the vertical light from the shell by using your hands to pull it free from the surrounding shell.
      询问修复机器人
      添加评论
    3. Hover-1 H1 LED Headlight Replacement: 步骤 7 中的图像 1,1
      • Remove two 8mm screws using a Phillips #0 screwdriver to rotate the screws counterclockwise.
      • Remove the horizontal light by using your fingers to pull the light up out of the shell.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018 的会员
CPSU-WHITE-F18S17G6
4 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 26
总计 1,708
