简介
In order to replace most parts in this saw, you will first need to remove this housing by unscrewing the nine screws located around the saw. If the housing is either broken or cracked. It can be easily replaced by following the steps below.
你所需要的
Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
2等其他人完成本指南。
