跳转到主内容
加入维修社区 - 创建账户
Hot Tools HPK12 Control Assembly Replacement
你所需要的
    1. Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: 步骤 1 中的图像 1,3 Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: 步骤 1 中的图像 2,3 Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: 步骤 1 中的图像 3,3
      • Remove round plastic cover near cord base by prying under the side with the metal spudger.
      • Flip the device and remove the other round plastic cover near the base of the cord.
      • Use the Phillips #1 screwdriver to remove the 5.5mm PH1 screw and washer under the plastic cover and set both aside.
      询问修复机器人
      添加评论
    2. Hot Tools HPK12 Control Assembly Replacement: 步骤 2 中的图像 1,1
      • Use the metal spudger to push the center pin through to the other side.
      询问修复机器人
      添加评论
    3. Hot Tools HPK12 Control Assembly Replacement: 步骤 3 中的图像 1,2 Hot Tools HPK12 Control Assembly Replacement: 步骤 3 中的图像 2,2
      • Lift back plastic cover to expose spring assembly.
      • Be careful not to damage the power cord by bending or twisting it too much while performing this step.
      • Grip the exposed end of the spring assembly and remove it.
      • The side with the two ends of the spring goes into the recessed area of the iron
      询问修复机器人
      添加评论
    4. Hot Tools HPK12 Control Assembly Replacement: 步骤 4 中的图像 1,1
      • Use the JIS #0 screwdriver to remove the two 3.5mm “J0” screws that attach the control assembly cover to the flat iron base.
      询问修复机器人
      添加评论
    5. Hot Tools HPK12 Control Assembly Replacement: 步骤 5 中的图像 1,3 Hot Tools HPK12 Control Assembly Replacement: 步骤 5 中的图像 2,3 Hot Tools HPK12 Control Assembly Replacement: 步骤 5 中的图像 3,3
      • Lift upward on the control assembly cover to remove it from the flat iron base.
      • Remove dial and switch cover and set aside.
      询问修复机器人
      添加评论
    6. Hot Tools HPK12 Control Assembly Replacement: 步骤 6 中的图像 1,3 Hot Tools HPK12 Control Assembly Replacement: 步骤 6 中的图像 2,3 Hot Tools HPK12 Control Assembly Replacement: 步骤 6 中的图像 3,3
      • Use your JIS #0 screw driver to remove the two 6mm “J0” screws that are attached to the flat iron base and set them aside.
      • Lift the backing plate upwards to remove it from the flat iron.
      • Use the Phillips #0 screwdriver to remove two 4mm “PH0” screws that attach the circuit assembly to the flat iron base.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
IUPUI, Team 3-4, Baechle Fall 2016 IUPUI, Team 3-4, Baechle Fall 2016 的会员
IUPUI-BAECHLE-F16S3G4
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 32
总计 3,221
