跳转到主内容
加入维修社区 - 创建账户
Hoover Power Path Pro Advanced Hose Replacement
你所需要的
    1. Hoover Power Path Pro Advanced Hose Replacement, Brush Roller: 步骤 1 中的图像 1,2 Hoover Power Path Pro Advanced Hose Replacement, Brush Roller: 步骤 1 中的图像 2,2
      • Unplug the vacuum cleaner from the wall outlet before starting. Make sure the water tanks are empty.
      • Lay the cleaner down horizontally with its wheels closest to the floor.
      添加评论
    2. Hoover Power Path Pro Advanced Hose Replacement: 步骤 2 中的图像 1,2 Hoover Power Path Pro Advanced Hose Replacement: 步骤 2 中的图像 2,2
      • Hold the lower brush roll with both hands and pull outwards until it is detached.
      询问修复机器人
      添加评论
    3. Hoover Power Path Pro Advanced Hose Replacement: 步骤 3 中的图像 1,1
      • Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
      • Remove the brush roller.
      添加评论
    1. Hoover Power Path Pro Advanced Hose Replacement, Hose: 步骤 4 中的图像 1,1
      • Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
      • They will also be indicated on the bottom of the vacuum.
      询问修复机器人
      添加评论
    2. Hoover Power Path Pro Advanced Hose Replacement: 步骤 5 中的图像 1,2 Hoover Power Path Pro Advanced Hose Replacement: 步骤 5 中的图像 2,2
      • Pull the red handle shown to remove the front suction unit from the cleaner.
      添加评论
    3. Hoover Power Path Pro Advanced Hose Replacement: 步骤 6 中的图像 1,1
      • Unscrew the Phillips #2 screw at the bottom of the hose.
      询问修复机器人
      添加评论
    4. Hoover Power Path Pro Advanced Hose Replacement: 步骤 7 中的图像 1,1
      • Grab the attachment at tip of the hose and unscrew it. Pull outwards on the hose until completely removed.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Cal Poly, Team S16-G5, Banghart Winter 2018 Cal Poly, Team S16-G5, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S16G5
5 名成员
创作了62篇指南
4指南评论
Where can I find this replacement hose?
Jennifer - 回复 分享
Complete waste of $$, won’t pick up water unless you apply about 40 lbs of downward force on the %#*@ thing, I tried all the trouble shooting tips, no change, maybe used 3 times. The attachment same thing nada. Basically a toy.
Leigh Robert Smith - 回复 分享
Where can I purchase the lower hose?
Eryk H. - 回复 分享
I've been trying to find the hose for mine for two years now I even called hoover and they tell me it's unavailable maybe I need to find a Hoover scrap yard lol if anyone knows where I can get one please let me know via email at jefferyalger1959@gmail.com
Jeffery Alger - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 38
总计 5,140
