跳转到主内容
加入维修社区 - 创建账户
Honda CSC29 Brushes Replacement
你所需要的
    1. Honda CSC29 Brushes Replacement, Alternator Front Cover: 步骤 1 中的图像 1,3 Honda CSC29 Brushes Replacement, Alternator Front Cover: 步骤 1 中的图像 2,3 Honda CSC29 Brushes Replacement, Alternator Front Cover: 步骤 1 中的图像 3,3
      • Remove 4, 7.9mm nuts using a 7.9mm socket driver head
      • One of the nuts is placed underneath the L-Bracket. Remove the L-Bracket and the 3 circled nuts before attempting to remove the remaining nut
      • There are two covers that need to be removed from the alternator. This step describes how to remove the back cover.
      询问修复机器人
      添加评论
    2. Honda CSC29 Brushes Replacement: 步骤 2 中的图像 1,3 Honda CSC29 Brushes Replacement: 步骤 2 中的图像 2,3 Honda CSC29 Brushes Replacement: 步骤 2 中的图像 3,3
      • Pull cover off the body of the alternator
      • Once you have done this, you should be able to see the internal components of the alternator, particularly the bridge assembly that houses the rectifier, voltage regulator and brushes.
      询问修复机器人
      添加评论
    1. Honda CSC29 Brushes Replacement, Brushes: 步骤 3 中的图像 1,3 Honda CSC29 Brushes Replacement, Brushes: 步骤 3 中的图像 2,3 Honda CSC29 Brushes Replacement, Brushes: 步骤 3 中的图像 3,3
      • You should now be able to see the recifier assembly, the brushes are located in the middle of the recifier assembly.
      • Remove the brush assembly by unscrewing 2, 6mm center screws using a #2 Phillips head screw driver
      询问修复机器人
      添加评论
    2. Honda CSC29 Brushes Replacement: 步骤 4 中的图像 1,3 Honda CSC29 Brushes Replacement: 步骤 4 中的图像 2,3 Honda CSC29 Brushes Replacement: 步骤 4 中的图像 3,3
      • Remove the brush assembly by pulling it out.
      添加评论
    3. Honda CSC29 Brushes Replacement: 步骤 5 中的图像 1,1
      • Inspect the brushes. If they are scored and not smooth you will need to replace the entire assembly.
      • When reinserting the brushes, make sure the springs keep the brushes in contact with the stator.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Cal Poly, Team 25-1, Maness Spring 2016 Cal Poly, Team 25-1, Maness Spring 2016 的会员
CPSU-MANESS-S16S25G1
4 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 32
总计 1,869
