简介
This guide shows how to remove and replace the carburetor for the Honda EU3000IS1AWK 3000 watt generator.
The guide lists all the gaskets encountered during the repair. You should replace any gasket that looks damaged or worn.
你所需要的
Use a large flathead screwdriver to unlock the maintenance cover.
Open the maintenance cover.
Unlatch the four clips securing the air cleaner cover.
Remove the air cleaner cover.
Pull and disconnect the breather tube from the top corner of the air cleaner housing.
Place a container below the carburetor drain tube to catch the excess fuel.
The carburetor drain screw is located at the bottom of the carburetor.
Use a flathead screwdriver to loosen the brass fuel drain screw until fuel begins to drain out of the carburetor.
Once you drain the fuel bowl, re-tighten the fuel drain screw.
2等其他人完成本指南。
