简介
This guide shows how to replace the Safety Switch on the Homelite UT44172 4.8-volt Cordless Grass Shear. The safety switch must be pressed simultaneously with the operating switch for the blades to move. If the safety switch is stuck or loose, then it or its spring may need to be replaced.
你所需要的
Remove the six 1.5 cm screws marked on the picture from the plastic casing with a Phillips #2 screwdriver.
Inspect both the spring and the switch to see if either is deformed or damaged. If so, replace the damaged part with a new part.
