跳转到主内容
加入维修社区 - 创建账户
HomePod Disassembly
你所需要的
  1. HomePod Disassembly, Top Touch Cover: 步骤 1 中的图像 1,2 HomePod Disassembly, Top Touch Cover: 步骤 1 中的图像 2,2
    • Be sure to unplug your HomePod before disassembly.
    • Using a hairdryer on hot, heat up the top touch surface and remove.
    • The cover is not flexible. Special care must be taken to avoid cracking or snapping the top cover.
    询问修复机器人
    添加评论
  2. HomePod Disassembly, Removing the Touch Surface: 步骤 2 中的图像 1,3 HomePod Disassembly, Removing the Touch Surface: 步骤 2 中的图像 2,3 HomePod Disassembly, Removing the Touch Surface: 步骤 2 中的图像 3,3
    • Remove four T6 screws.
    • Using a hair dryer on hot, soften the adhesive holding the touch pad assembly to the top frame.
    • Using a guitar pick, carefully pry up the touch pad.
    询问修复机器人
    添加评论
  3. HomePod Disassembly, Disconnecting the Touch Surface: 步骤 3 中的图像 1,3 HomePod Disassembly, Disconnecting the Touch Surface: 步骤 3 中的图像 2,3 HomePod Disassembly, Disconnecting the Touch Surface: 步骤 3 中的图像 3,3
    • Maneuver the touch assembly board up from the top frame.
    • Flip the retaining lever upwards with a spudger to release the ribbon cable.
    • Remove the ribbon cable from the connector.
    询问修复机器人
    添加评论
  4. HomePod Disassembly, 3D Mesh Draw Strings: 步骤 4 中的图像 1,3 HomePod Disassembly, 3D Mesh Draw Strings: 步骤 4 中的图像 2,3 HomePod Disassembly, 3D Mesh Draw Strings: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Using tweezers (or fingers) unwind the drawstrings from the moorings.
    • The drawstrings are wrapped/looped around each T6 screw post. Remove or loosen each and unwrap the drawstring.
    询问修复机器人
    添加评论
  5. HomePod Disassembly, Touch Surface Support Plate: 步骤 5 中的图像 1,2 HomePod Disassembly, Touch Surface Support Plate: 步骤 5 中的图像 2,2
    • Remove the four T6 screws securing the touch surface support disc to the lid and slide the 3D mesh fabric sleeve downwards.
    • Remove the touch surface support frame disk from the HomePod.
    询问修复机器人
    添加评论
  6. HomePod Disassembly, Logic Board Removal: 步骤 6 中的图像 1,3 HomePod Disassembly, Logic Board Removal: 步骤 6 中的图像 2,3 HomePod Disassembly, Logic Board Removal: 步骤 6 中的图像 3,3
    • Flip the logic board up and using a spudger, carefully pry the retaining lever upwards.
    • Pop the ribbon cable straight upwards and out. This cable has "ears" on each side and doesn't not slide into the connector.
    添加评论
  7. HomePod Disassembly, Top Cover Removal (screws): 步骤 7 中的图像 1,3 HomePod Disassembly, Top Cover Removal (screws): 步骤 7 中的图像 2,3 HomePod Disassembly, Top Cover Removal (screws): 步骤 7 中的图像 3,3
    • Using a spudger, remove the nine rubber screw caps.
    • Using a Torx T6 screwdriver, remove the nine T6 screws securing the top to the main housing.
    询问修复机器人
    添加评论
  8. HomePod Disassembly, Softening the Adhesive: 步骤 8 中的图像 1,3 HomePod Disassembly, Softening the Adhesive: 步骤 8 中的图像 2,3 HomePod Disassembly, Softening the Adhesive: 步骤 8 中的图像 3,3
    • Using a hairdryer on high heat, aim the hairdryer as shown and heat the perimeter just below the seam where the top meets the main housing.
    • This step is critical. If you have trouble with the next step, repeat the heating process in the trouble area.
    询问修复机器人
    添加评论
  9. HomePod Disassembly, Separating the Top: 步骤 9 中的图像 1,3 HomePod Disassembly, Separating the Top: 步骤 9 中的图像 2,3 HomePod Disassembly, Separating the Top: 步骤 9 中的图像 3,3
    • This step requires significant force even with plenty of heat applied in the previous step.
    • Insert a wide flat blade screwdriver wrapped in 1-2 layers of electrical tape.
    • You will need to apply a fair amount of pressure to wedge the screwdriver head in the small gap.
    • Pull the top cover straight up. This will need to be done in four sections.
    添加评论
  10. HomePod Disassembly, Top Removal (continued): 步骤 10 中的图像 1,3 HomePod Disassembly, Top Removal (continued): 步骤 10 中的图像 2,3 HomePod Disassembly, Top Removal (continued): 步骤 10 中的图像 3,3
    • Be careful when freeing the top from the glue. The ribbon cable we disconnected in Step 7 is adhered to the top and can easily become torn.
    添加评论
  11. HomePod Disassembly, Top Removal (continued 2): 步骤 11 中的图像 1,2 HomePod Disassembly, Top Removal (continued 2): 步骤 11 中的图像 2,2
    • Careful peel the ribbon cable from the top.
    • Take your time as you don't want to tear this cable.
    添加评论
  12. HomePod Disassembly, Woofer Removal: 步骤 12 中的图像 1,3 HomePod Disassembly, Woofer Removal: 步骤 12 中的图像 2,3 HomePod Disassembly, Woofer Removal: 步骤 12 中的图像 3,3
    • Remove the six Torx T6 screws securing the woofer.
    • Carefully lift the woofer out by it's edges and slip the logic board ribbon cable through.
    询问修复机器人
    添加评论
  13. HomePod Disassembly, Disconnecting the Woofer: 步骤 13 中的图像 1,3 HomePod Disassembly, Disconnecting the Woofer: 步骤 13 中的图像 2,3 HomePod Disassembly, Disconnecting the Woofer: 步骤 13 中的图像 3,3
    • Support the woofer on the top edge of the HomePod with your hand.
    • With your other hand, reach inside and squeeze the tab on the connector and pull strait up to disconnect the woofer from the amplifier board.
    • Remove the woofer from the HomePod.
    询问修复机器人
    添加评论
  14. HomePod Disassembly, Woofer Gasket: 步骤 14 中的图像 1,3 HomePod Disassembly, Woofer Gasket: 步骤 14 中的图像 2,3 HomePod Disassembly, Woofer Gasket: 步骤 14 中的图像 3,3
    • Remove the woofer's gasket.
    • This is a simple, yet critical part and sealing the enclosure with the driver installed. Failure to replace this gasket will result in degradation of sound and excessive air noise.
    询问修复机器人
    添加评论
  15. HomePod Disassembly, Upper Ring Removal: 步骤 15 中的图像 1,3 HomePod Disassembly, Upper Ring Removal: 步骤 15 中的图像 2,3 HomePod Disassembly, Upper Ring Removal: 步骤 15 中的图像 3,3
    • Remove the six Torx T6 screws.
    • Note the small delicate rubber O rings that go with each screw. Replace any damaged or missing O rings.
    询问修复机器人
    添加评论
  16. HomePod Disassembly, Upper Ring Removal (Continued): 步骤 16 中的图像 1,3 HomePod Disassembly, Upper Ring Removal (Continued): 步骤 16 中的图像 2,3 HomePod Disassembly, Upper Ring Removal (Continued): 步骤 16 中的图像 3,3
    • Using a spudger, push the silicone grommet through the upper ring.
    • Remove the upper ring from the HomePod.
    询问修复机器人
    添加评论
  17. HomePod Disassembly, Middle Ring Removal: 步骤 17 中的图像 1,3 HomePod Disassembly, Middle Ring Removal: 步骤 17 中的图像 2,3 HomePod Disassembly, Middle Ring Removal: 步骤 17 中的图像 3,3
    • With the upper ring removed, remove the grommet from the ribbon cable.
    • Rotate the middle ring counter clockwise to unscrew it from the HomePod.
    添加评论
  18. HomePod Disassembly, Power Supply Removal: 步骤 18 中的图像 1,3 HomePod Disassembly, Power Supply Removal: 步骤 18 中的图像 2,3 HomePod Disassembly, Power Supply Removal: 步骤 18 中的图像 3,3
    • Push down on the locking tab and pull in the direction of the arrow.
    • Remove the four Torx T6 screws securing the power supply to the amplifier board.
    询问修复机器人
    添加评论
  19. HomePod Disassembly, Power Supply Removal Tips: 步骤 19 中的图像 1,3 HomePod Disassembly, Power Supply Removal Tips: 步骤 19 中的图像 2,3 HomePod Disassembly, Power Supply Removal Tips: 步骤 19 中的图像 3,3
    • Be sure to pull straight up (orange arrow) when removing the power supply (after removing the screws). This connector is fragile and easily damaged during removal and installation!
    • The third photo shows how the power supply board properly mates with the amplifier board.
    询问修复机器人
    添加评论
  20. HomePod Disassembly, Amplifier Board Removal: 步骤 20 中的图像 1,3 HomePod Disassembly, Amplifier Board Removal: 步骤 20 中的图像 2,3 HomePod Disassembly, Amplifier Board Removal: 步骤 20 中的图像 3,3
    • Disconnect the ribbon cable connecting the amplifier board to the logic board.
    • Remove the 14 Torx T6 screws securing the amplifier board to the 7 tweeters.
    • Carefully lift out and remove the amplifier board from the HomePod.
    添加评论
  21. HomePod Disassembly, Microphone Board Removal: 步骤 21 中的图像 1,3 HomePod Disassembly, Microphone Board Removal: 步骤 21 中的图像 2,3 HomePod Disassembly, Microphone Board Removal: 步骤 21 中的图像 3,3
    • Disconnect the 3 ribbon cables from the Microphone board.
    • Using a hair dryer, heat the microphone board from the back side.
    • Using a plastic spudger, remove the PCB from the housing.
    询问修复机器人
    添加评论
  22. HomePod Disassembly, Tweeter Retaining Ring: 步骤 22 中的图像 1,3 HomePod Disassembly, Tweeter Retaining Ring: 步骤 22 中的图像 2,3 HomePod Disassembly, Tweeter Retaining Ring: 步骤 22 中的图像 3,3
    • This is difficult to do, but with two spudgers and a finger nail, it's possible.
    • Using one hand to depress the 2 spiders and a finger nail to depress the 3rd clip, use your free hand to unscrew (counter clockwise) the tweeter retaining ring.
    • It is only necessary to rotate the tweeter retention ring several turns. It is not necessary to remove it entirely.
    询问修复机器人
    添加评论
  23. HomePod Disassembly, Tweeter Removal: 步骤 23 中的图像 1,2 HomePod Disassembly, Tweeter Removal: 步骤 23 中的图像 2,2
    • Remove the three screws that secure the tweeter in place.
    询问修复机器人
    添加评论
  24. HomePod Disassembly, Main Ribbon Cable Removal: 步骤 24 中的图像 1,3 HomePod Disassembly, Main Ribbon Cable Removal: 步骤 24 中的图像 2,3 HomePod Disassembly, Main Ribbon Cable Removal: 步骤 24 中的图像 3,3
    • Remove the two T6 screws securing the diagnostic port to the bottom housing
    • Careful peel the ribbon cable from the wall of the HomePod. Take care not to tear this cable.
    • Remember it helps to heat the outside of the housing near the ribbon cable with a hair dryer to soften the adhesive securing this ribbon cable in place.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
17等其他人完成本指南。
Nicholas Ouimet
于10/16/09注册
3,680 声望
创作了11篇指南
8指南评论
Probably one of the hardest Apple product I've disassembled, took me almost an hour to remove the top.
Thank you for your guide!
Lulucmy - 回复 分享
My homepod was knocked off a table during a party and started buzzing like crazy with any bass. I was able to follow this, and remove the woofer with no problems. turns out the woofer cage had bent unsealing the woofer, i was able to hammer it straight, reassemble, and it works perfectly again. THANK YOU.
mn mongo - 回复 分享
What's the best way to test the PSU? My HomePod bricked, I disassembled it using this guide (Thank you!), the cable checks out, the next suspect is the PSU.
yarikos - 回复 分享
Thank you for the information, it is really very useful.
A family member gave me his first generation Homepod which is not working after a fall from a table. Due to its age it is out of warranty and was not repaired or replaced by the official Apple service. He tried unsuccessfully to repair it.
Today I opened it up and the flat cable that connects the motherboard to other components on the bottom of the device is broken very close to its connection to this motherboard.
I really don't think this is the original fault of the device but I would like to know if there is a possibility to repair or replace this cable.
Thank you very much.
Guiseppe - 回复 分享
Someone in Mexico that repairs Homepod First version/Alguien en mexico que repare homepod primera version
Homero Amaro Lira - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 250
过去 30 天: 928
总计 38,901
