此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
在这个步骤中使用的工具:Tweezers$4.99
使用 镊子(或手指)将抽绳从系留点上解开。
抽绳缠绕在每个 T6 螺丝柱上。拆下或松开每一个螺丝,然后解开抽绳。
用手托住 HomePod 顶部的低音扬声器。
用另一只手伸入内部,挤压连接器上的卡扣并垂直向上拉,将低音扬声器从放大器板上断开。
将低音扬声器从 HomePod 中取出。
要重新组装设备,请按相反顺序执行这些说明。
19等其他人完成本指南。
9指南评论
My homepod was knocked off a table during a party and started buzzing like crazy with any bass. I was able to follow this, and remove the woofer with no problems. turns out the woofer cage had bent unsealing the woofer, i was able to hammer it straight, reassemble, and it works perfectly again. THANK YOU.
Thank you for the information, it is really very useful.
A family member gave me his first generation Homepod which is not working after a fall from a table. Due to its age it is out of warranty and was not repaired or replaced by the official Apple service. He tried unsuccessfully to repair it.
Today I opened it up and the flat cable that connects the motherboard to other components on the bottom of the device is broken very close to its connection to this motherboard.
I really don't think this is the original fault of the device but I would like to know if there is a possibility to repair or replace this cable.
Thank you very much.
Someone in Mexico that repairs Homepod First version/Alguien en mexico que repare homepod primera version
