跳转到主内容
加入维修社区 - 创建账户
Holmes HEH8031 Control Buttons Replacement
你所需要的
    1. Holmes HEH8031 Control Buttons Replacement, Housing: 步骤 1 中的图像 1,1
      • Ensure the device is unplugged from the wall outlet.
      询问修复机器人
      添加评论
    2. Holmes HEH8031 Control Buttons Replacement: 步骤 2 中的图像 1,1
      • Remove eight 12-mm Phillips #2 screws from the back cover.
      询问修复机器人
      添加评论
    3. Holmes HEH8031 Control Buttons Replacement: 步骤 3 中的图像 1,2 Holmes HEH8031 Control Buttons Replacement: 步骤 3 中的图像 2,2
      • Turn heater over so the controls are facing up.
      • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
      • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
      询问修复机器人
      添加评论
    1. Holmes HEH8031 Control Buttons Replacement, Circuit Board Removal: 步骤 4 中的图像 1,1
      • Remove four 12mm Phillips #2 screws from the circuit board.
      询问修复机器人
      添加评论
    1. Holmes HEH8031 Control Buttons Replacement, Control Buttons: 步骤 5 中的图像 1,3 Holmes HEH8031 Control Buttons Replacement, Control Buttons: 步骤 5 中的图像 2,3 Holmes HEH8031 Control Buttons Replacement, Control Buttons: 步骤 5 中的图像 3,3
      • Remove the two Phillips #2 12mm screws from the button retainer.
      • Lift the button retainer off.
      • Remove the interconnected buttons.
      • If the buttons are broken, replace them.
      • If the buttons are sticking, clean them in warm soapy water and allow to dry.
      询问修复机器人
      添加评论
    2. Holmes HEH8031 Control Buttons Replacement: 步骤 6 中的图像 1,3 Holmes HEH8031 Control Buttons Replacement: 步骤 6 中的图像 2,3 Holmes HEH8031 Control Buttons Replacement: 步骤 6 中的图像 3,3
      • Using light finger pressure, carefully push the black plastic tabs off the white plastic hooks.
      • Remove the black plastic bracket out through the front of the heater housing.
      • Remove the two Phillips #2 12mm screws and remove the clear window from the black plastic bracket.
      • If the buttons were sticking, clean the black plastic bracket in warm soapy water and allow to dry.
      • If the clear window was dirty, clean it in warm soapy water and allow to dry.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Chris Shaffer
于10/12/16注册
255 声望
创作了2篇指南
团队
IUPUI, Team 2-1, Baechle Fall 2016 IUPUI, Team 2-1, Baechle Fall 2016 的会员
IUPUI-BAECHLE-F16S2G1
4 名成员
创作了48篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 863
