跳转到主内容
加入维修社区 - 创建账户
Harman Kardon Esquire Mini External Stand Replacement
你所需要的
    1. Harman Kardon Esquire Mini External Stand  Replacement, Front Panel: 步骤 1 中的图像 1,1
      • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
      • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
      询问修复机器人
      添加评论
    2. Harman Kardon Esquire Mini External Stand  Replacement: 步骤 2 中的图像 1,1
      • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
      • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
      • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
      询问修复机器人
      添加评论
    1. Harman Kardon Esquire Mini External Stand  Replacement, External Stand: 步骤 3 中的图像 1,1
      • Using the Pentalobe screw driver, unscrew the 5.1 mm screws by applying a clockwise force.
      • Remove all of the 5.1 mm screws, and slowly lift the stand. There are 4 screws on the stand.
      • After the stand is removed, replace the stand with a new one.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
USF Tampa, Team S1-G9, Cagle Fall 2017 USF Tampa, Team S1-G9, Cagle Fall 2017 的会员
USFT-CAGLE-F17S1G9
5 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 36
总计 970
