跳转到主内容
加入维修社区 - 创建账户
Hamilton Beach 51101BA Blades Replacement
你所需要的
    1. Hamilton Beach 51101BA Blades Replacement, Blades: 步骤 1 中的图像 1,1
      • Remove the lid from the container by holding the base and pulling up on the lid.
      询问修复机器人
      添加评论
    2. Hamilton Beach 51101BA Blades Replacement: 步骤 2 中的图像 1,3 Hamilton Beach 51101BA Blades Replacement: 步骤 2 中的图像 2,3 Hamilton Beach 51101BA Blades Replacement: 步骤 2 中的图像 3,3
      • Remove the container from the blender.
      • Hold the blender and the container, then twist the container in a clockwise motion.
      • Make sure to follow the lock and unlock markings on the container.
      询问修复机器人
      添加评论
    3. Hamilton Beach 51101BA Blades Replacement: 步骤 3 中的图像 1,3 Hamilton Beach 51101BA Blades Replacement: 步骤 3 中的图像 2,3 Hamilton Beach 51101BA Blades Replacement: 步骤 3 中的图像 3,3
      • Avoid placing your fingers on the blade, as they could be sharp.
      • Using a pair of pliers to hold the blade in place, use your other hand to unscrew the rubber piece on the bottom of the container.
      • Remove the rubber piece and the two washers by rotating the rubber piece counter-clockwise.
      询问修复机器人
      添加评论
    4. Hamilton Beach 51101BA Blades Replacement: 步骤 4 中的图像 1,1
      • Carefully, pull the blades out of the container as they are very sharp.
      • Using the pliers, remove blades and the washer around the blade shaft.
      添加评论
结论
To reassemble your device with the new blade assembly, follow these instructions in reverse order.
取消:我没有完成这个指南。
7等其他人完成本指南。
团队
USF Tampa, Team 2-5, Sullivan Fall 2015 USF Tampa, Team 2-5, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S2G5
4 名成员
创作了22篇指南
3指南评论
Need to know how to install parts and how many
papi3701@aol.com - 回复 分享
Looks like I missed parts need to know the order son cuantaty
For my 501101B blender, the whole blade assembly popped out, so the blended smoothie draws at the bottom like a water falls How to fix this?
Joyful Joy - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 47
过去 30 天: 181
总计 14,209
