跳转到主内容
加入维修社区 - 创建账户
Hair Dryer Fan/ Motor Assembly Replacement
你所需要的
  1. Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: 步骤 1 中的图像 1,2 Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: 步骤 1 中的图像 2,2
    • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
    • If nozzle is not attached, skip to next step.
    询问修复机器人
    添加评论
  2. Hair Dryer Fan/ Motor Assembly Replacement, Grating: 步骤 2 中的图像 1,1
    • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
    询问修复机器人
    添加评论
  3. Hair Dryer Fan/ Motor Assembly Replacement: 步骤 3 中的图像 1,1
    • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
    询问修复机器人
    添加评论
  4. Hair Dryer Fan/ Motor Assembly Replacement: 步骤 4 中的图像 1,1
    • Separate the hair dryer grating into the three pieces seen in the image.
    询问修复机器人
    添加评论
  5. Hair Dryer Fan/ Motor Assembly Replacement, Fan/ Motor Assembly: 步骤 5 中的图像 1,1
    • Locate the screws on the handle and remove with a Phillips screwdriver.
    询问修复机器人
    添加评论
  6. Hair Dryer Fan/ Motor Assembly Replacement: 步骤 6 中的图像 1,1
    • Carefully separate the plastic case with the Plastic Opening Tool.
    询问修复机器人
    添加评论
  7. Hair Dryer Fan/ Motor Assembly Replacement: 步骤 7 中的图像 1,1
    • After removing the plastic case, locate the fan towards the back of the hair dryer.
    询问修复机器人
    添加评论
  8. Hair Dryer Fan/ Motor Assembly Replacement: 步骤 8 中的图像 1,1
    • Remove the screw that is holding the fan to the motor using a Phillips screwdriver.
    询问修复机器人
    添加评论
  9. Hair Dryer Fan/ Motor Assembly Replacement: 步骤 9 中的图像 1,1
    • Remove the screws holding the motor to the casing using a Phillips screwdriver.
    • NOTE: This may be unnecessary if the fan can be removed without using a screwdriver.
    询问修复机器人
    添加评论
  10. Hair Dryer Fan/ Motor Assembly Replacement: 步骤 10 中的图像 1,1
    • Isolate the fan from the rest of the dryer.
    • Remove the screws holding the motor in place. Replace with the new component.
    询问修复机器人
    添加评论
  11. Hair Dryer Fan/ Motor Assembly Replacement: 步骤 11 中的图像 1,1
    • Solder the wires to the motor. Refer to the soldering page below, which will help you replace this component.
    • Soldering Skills
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Mitch
于10/04/12注册
37 声望
创作了5篇指南
团队
Cal Poly, Team 24-29, Regan Fall 2012 Cal Poly, Team 24-29, Regan Fall 2012 的会员
CPSU-REGAN-F12S24G29
5 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 129
总计 18,219
