跳转到主内容
加入维修社区 - 创建账户
HVAC Filter Replacement
你所需要的
  1. HVAC Filter Replacement, Filter: 步骤 1 中的图像 1,1
    • Observe your air conditioning vent. If the filter appears to be dirty or damaged, then it is time to change it.
    询问修复机器人
    添加评论
  2. HVAC Filter Replacement: 步骤 2 中的图像 1,1
    • Remove the screws on the vent cover. There should be a minimum of 4 screws in each corner of the vent.
    • The screws in this vent are phillips hex head screws that are 1 3/4 in. long.
    询问修复机器人
    添加评论
  3. HVAC Filter Replacement: 步骤 3 中的图像 1,1
    • Grab a screwdriver with a hex head attachment to remove the screws. Grab the screwdriver and place it on the head of the screw. Twist in a counterclockwise motion until the screw is removed. Repeat for every screw.
    询问修复机器人
    添加评论
  4. HVAC Filter Replacement: 步骤 4 中的图像 1,1
    • Remove the vent cover to access the ventilation filter.
    询问修复机器人
    添加评论
  5. HVAC Filter Replacement: 步骤 5 中的图像 1,1
    • Optional: Put on a latex glove on the hand that you will use to remove the filter.
    询问修复机器人
    添加评论
  6. HVAC Filter Replacement: 步骤 6 中的图像 1,1
    • Remove the filter carefully.
    • Make sure to remove it slowly so that the dust does not come of it.
    询问修复机器人
    添加评论
  7. HVAC Filter Replacement: 步骤 7 中的图像 1,1
    • Dispose of the old filter in a waste bin.
    询问修复机器人
    添加评论
  8. HVAC Filter Replacement: 步骤 8 中的图像 1,1
    • Buy a Honeywell Air Filter from Home Depot and make sure to buy the filter with the correct dimensions.
    • The dimensions for filters will vary depending on the dimensions of the vent.
    • In this case, my vent was 14x25x1 and thus needed a filter with the same dimensions.
    询问修复机器人
    添加评论
  9. HVAC Filter Replacement: 步骤 9 中的图像 1,1
    • Place the new filter into the vent opening. Make sure that it is facing the right direction.
    • There will be an arrow on the side of the filter showing which way to place it.
    询问修复机器人
    添加评论
  10. HVAC Filter Replacement: 步骤 10 中的图像 1,1
    • Place vent cover.
    询问修复机器人
    添加评论
  11. HVAC Filter Replacement: 步骤 11 中的图像 1,1
    • Grab the same screws that were taken out at Step 3 and use them to secure the vent cover.
    • Place the screwdriver on the head of the screw and twist in a clockwise motion until screw is secure.
    • Repeat for every screw.
    询问修复机器人
    添加评论
  12. HVAC Filter Replacement: 步骤 12 中的图像 1,1
    • Turn on your air conditioner to make sure the filter does not move.
    • If the filter does not move, then you have successfully replaced the filter of your air conditioner.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
CSU Los Angeles, Team 2-1, Briggs Fall 2023 CSU Los Angeles, Team 2-1, Briggs Fall 2023 的会员
CSULA-BRIGGS-F23S2G1
5 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 51
总计 906
