简介
This guide will explain how to install / remove the keypad from the HTC Wizard 200.
你所需要的
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
在这个步骤中使用的工具:Spudger$3.99
Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
在这个步骤中使用的工具:T5 Torx Screwdriver$5.49
Remove the four 6 mm screws with the T5 Torx screwdriver.
Remove the four 5mm screws with the T5 Torx screwdriver.
Remove the keyboard slider from the main body.
Use a screwdriver to remove eight 2mm Phillips screws that secure the keypad to the keyboard slider.
