简介
This guide takes you through the steps to install the front panel buttons.
你所需要的
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
在这个步骤中使用的工具:Spudger$3.99
Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
在这个步骤中使用的工具:T5 Torx Screwdriver$5.49
Remove the four 6 mm screws with the T5 Torx screwdriver.
Remove the four 5mm screws with the T5 Torx screwdriver.
Remove the keyboard slider from the main body.
Use the T5 Torx screwdriver to remove four 5mm screws that secure the back of the screen casing.
