跳转到主内容
加入维修社区 - 创建账户
HTC Wizard 100 Camera Replacement
你所需要的
    1. HTC Wizard 100 Camera Replacement, Battery: 步骤 1 中的图像 1,2 HTC Wizard 100 Camera Replacement, Battery: 步骤 1 中的图像 2,2
      • Power the phone off.
      • Use your thumb to gently press downward and away from the camera to remove the battery cover.
      询问修复机器人
      添加评论
    2. HTC Wizard 100 Camera Replacement: 步骤 2 中的图像 1,2 HTC Wizard 100 Camera Replacement: 步骤 2 中的图像 2,2
      • Pull on the plastic tab to release the battery.
      询问修复机器人
      添加评论
    1. HTC Wizard 100 Camera Replacement, Back Case: 步骤 3 中的图像 1,2 HTC Wizard 100 Camera Replacement, Back Case: 步骤 3 中的图像 2,2
      • Use a plastic opening tool to remove the camera cover.
      • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
      • Lift the camera cover off of the phone.
      询问修复机器人
      添加评论
    2. HTC Wizard 100 Camera Replacement: 步骤 4 中的图像 1,1
      • Remove the stylus from the phone.
      • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
      • One of the screws might be under a sticker, which will void your warranty.
      询问修复机器人
      添加评论
    3. HTC Wizard 100 Camera Replacement: 步骤 5 中的图像 1,3 HTC Wizard 100 Camera Replacement: 步骤 5 中的图像 2,3 HTC Wizard 100 Camera Replacement: 步骤 5 中的图像 3,3
      • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
      • If your phone contains a memory card, you may want to remove it before proceeding with this step.
      • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
      • Lift the back case off completely.
      • The speakers might be dangling and unsecured.
      询问修复机器人
      添加评论
    1. HTC Wizard 100 Camera Replacement, Camera: 步骤 6 中的图像 1,1
      • Locate the camera and pry off with the plastic opening tool or spudger.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 20-28, Maness Fall 2011 Cal Poly, Team 20-28, Maness Fall 2011 的会员
CPSU-MANESS-F11S20G28
4 名成员
创作了39篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 19
总计 1,072
