跳转到主内容
HTC Vive XR Elite Proximity Sensor Replacement
你所需要的
  1. HTC Vive XR Elite Proximity Sensor Replacement, Prepare your Vive XR Elite for disassembly: 步骤 1 中的图像 1,1
    • Before starting this repair, discharge the batteries in your headset below 25%. A charged battery may leak dangerous chemicals or catch fire if damaged.
    • Playing Half Life: Alyx will do the trick!
    • The Vive XR Elite has a proximity sensor that puts the headset in standby mode to save battery when it isn't in use. To drain the battery faster you'll need to use the headset.
  2. HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the USB-C power cable: 步骤 2 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the USB-C power cable: 步骤 2 中的图像 2,2
    • Disconnect the USB-C power cable.
  3. HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the battery cradle: 步骤 3 中的图像 1,3 HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the battery cradle: 步骤 3 中的图像 2,3 HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the battery cradle: 步骤 3 中的图像 3,3
    • Press the release button on the right battery cradle temple slot.
    • Pull the battery cradle away from the right temple slot to disconnect it.
  4. HTC Vive XR Elite Proximity Sensor Replacement: 步骤 4 中的图像 1,3 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 4 中的图像 2,3 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 4 中的图像 3,3
    • Repeat the previous step for the left temple slot.
  5. HTC Vive XR Elite Proximity Sensor Replacement, Separate the headset and battery cradle: 步骤 5 中的图像 1,1
    • Separate the headset and battery cradle.
  6. HTC Vive XR Elite Proximity Sensor Replacement, Remove the face cushion: 步骤 6 中的图像 1,3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the face cushion: 步骤 6 中的图像 2,3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the face cushion: 步骤 6 中的图像 3,3
    • The face cushion is attached to the headset with two magnets. You'll feel the pull of the magnets as you remove it.
    • Grip the middle of the face cushion with your fingers and pull back to remove it.
  7. HTC Vive XR Elite Proximity Sensor Replacement, Remove the screw covers: 步骤 7 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement, Remove the screw covers: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to remove the six screw covers from the right temple.
  8. HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the right temple: 步骤 8 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the right temple: 步骤 8 中的图像 2,2
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two right temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the right hinge cover.
  9. HTC Vive XR Elite Proximity Sensor Replacement, Remove the outer hinge cover: 步骤 9 中的图像 1,3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the outer hinge cover: 步骤 9 中的图像 2,3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the outer hinge cover: 步骤 9 中的图像 3,3
    • Insert the flat end of a spudger in the gap between the right outer and inner hinge covers.
    • Slide the spudger along the gap to separate the clips securing the outer hinge cover.
    • Remove the outer hinge cover.
  10. HTC Vive XR Elite Proximity Sensor Replacement, Remove the outer temple: 步骤 10 中的图像 1,3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the outer temple: 步骤 10 中的图像 2,3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the outer temple: 步骤 10 中的图像 3,3
    • Insert the flat end of a spudger in the gap between the outer and inner temple.
    • Slide the spudger along the gap to separate the clips securing the outer temple.
  11. HTC Vive XR Elite Proximity Sensor Replacement: 步骤 11 中的图像 1,3 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 11 中的图像 2,3 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 11 中的图像 3,3
    • Slide the top of the outer temple out of its slot in the hinge.
  12. HTC Vive XR Elite Proximity Sensor Replacement: 步骤 12 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 12 中的图像 2,2
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $6.99
    • The speaker is lightly adhered to the outer temple.
    • Rotate the outer temple towards you to access the speaker.
    • Slide the flat end of a spudger under the speaker to separate its adhesive.
    • During reassembly, if your speaker adhesive isn't sticky, use double-sided tape to re-adhere the speaker to the outer temple.
  13. HTC Vive XR Elite Proximity Sensor Replacement: 步骤 13 中的图像 1,3 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 13 中的图像 2,3 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 13 中的图像 3,3
    • Thread the outer temple off of the USB‑C cable and remove it.
  14. HTC Vive XR Elite Proximity Sensor Replacement: 步骤 14 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 14 中的图像 2,2
    • Pull the inner temple out of its slot in the hinge and remove it.
  15. HTC Vive XR Elite Proximity Sensor Replacement, Peel the hinge tape: 步骤 15 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement, Peel the hinge tape: 步骤 15 中的图像 2,2
    • Use tweezers to peel back the black tape covering one of the inner hinge cover screws.
  16. HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the inner hinge cover: 步骤 16 中的图像 1,1
    • Use a T5 Torx screwdriver to remove the two screws securing the inner hinge cover:
    • One 3.1 mm‑long screw
    • One 4.9 mm‑long screw
  17. HTC Vive XR Elite Proximity Sensor Replacement, Remove the inner hinge cover: 步骤 17 中的图像 1,3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the inner hinge cover: 步骤 17 中的图像 2,3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the inner hinge cover: 步骤 17 中的图像 3,3
    • Rotate the inner hinge cover off its groove in the frame.
    • Thread the inner hinge cover off of the USB-C and speaker cables and remove it.
  18. HTC Vive XR Elite Proximity Sensor Replacement, Remove the screw covers: 步骤 18 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement, Remove the screw covers: 步骤 18 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to remove the six screw covers from the left temple.
  19. HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the left temple: 步骤 19 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the left temple: 步骤 19 中的图像 2,2
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two left temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the left hinge cover.
  20. HTC Vive XR Elite Proximity Sensor Replacement, Remove the outer hinge cover: 步骤 20 中的图像 1,3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the outer hinge cover: 步骤 20 中的图像 2,3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the outer hinge cover: 步骤 20 中的图像 3,3
    • Insert the flat end of a spudger in the gap between the left outer and inner hinge covers.
  21. HTC Vive XR Elite Proximity Sensor Replacement, Remove the left temple: 步骤 21 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement, Remove the left temple: 步骤 21 中的图像 2,2
    • Pull the left temple out of its slot in the hinge.
    • Don't try to fully remove it yet, as it's still connected by a cable.
  22. HTC Vive XR Elite Proximity Sensor Replacement: 步骤 22 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 22 中的图像 2,2
    • Slide the spudger along the gap to separate the plastic clips securing the outer temple.
  23. HTC Vive XR Elite Proximity Sensor Replacement: 步骤 23 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 23 中的图像 2,2
    • Pull the outer temple off of its inner half to completely release its plastic clips.
  24. HTC Vive XR Elite Proximity Sensor Replacement: 步骤 24 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 24 中的图像 2,2
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $6.99
    • Let the speaker rest next to the headset before continuing.
    • During reassembly, if your speaker adhesive isn't sticky, use Tesa 61395 Tape to re-adhere the speaker to the outer temple.
  25. HTC Vive XR Elite Proximity Sensor Replacement, Peel the hinge tape: 步骤 25 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement, Peel the hinge tape: 步骤 25 中的图像 2,2
  26. HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the inner hinge cover: 步骤 26 中的图像 1,1
    • One 3.5 mm‑long screw
  27. HTC Vive XR Elite Proximity Sensor Replacement, Reposition the inner hinge cover: 步骤 27 中的图像 1,3 HTC Vive XR Elite Proximity Sensor Replacement, Reposition the inner hinge cover: 步骤 27 中的图像 2,3 HTC Vive XR Elite Proximity Sensor Replacement, Reposition the inner hinge cover: 步骤 27 中的图像 3,3
    • Don't fully remove the inner hinge cover, as it's connected by the volume button cable.
    • Let the cover hang off its volume button cable for now.
  28. HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the face plate: 步骤 28 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the face plate: 步骤 28 中的图像 2,2
    • Use a T5 Torx screwdriver to remove the 12 screws securing the face plate:
    • Six 3.5 mm‑long screws
    • Four 4.9 mm‑long screws
    • Two 6.5 mm‑long screws
    • There are two magnets at the top corners of the face plate. As you remove nearby screws, they might stick to them.
  29. HTC Vive XR Elite Proximity Sensor Replacement, Unclip the face cover: 步骤 29 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement, Unclip the face cover: 步骤 29 中的图像 2,2
    • Insert the flat end of the spudger in the gap between the frame and the bottom right corner of the face cover.
    • Pry up with the spudger to release the clips securing the face cover.
  30. HTC Vive XR Elite Proximity Sensor Replacement: 步骤 30 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 30 中的图像 2,2
    • Repeat the prying process for the middle and bottom left portions of the face cover.
  31. HTC Vive XR Elite Proximity Sensor Replacement, Reposition the face cover: 步骤 31 中的图像 1,3 HTC Vive XR Elite Proximity Sensor Replacement, Reposition the face cover: 步骤 31 中的图像 2,3 HTC Vive XR Elite Proximity Sensor Replacement, Reposition the face cover: 步骤 31 中的图像 3,3
    • Don't fully remove the face cover completely, as it's connected by the proximity sensor cable.
    • Lift the face cover and rotate it over the top of the frame.
    • Lay the face cover face up before continuing.
  32. HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the proximity sensor: 步骤 32 中的图像 1,1
    • Use a T5 Torx screwdriver to remove the two 3.3 mm‑long screws securing the proximity sensor cable.
  33. HTC Vive XR Elite Proximity Sensor Replacement, Remove the face cover: 步骤 33 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement, Remove the face cover: 步骤 33 中的图像 2,2
    • Remove the face cover.
  34. HTC Vive XR Elite Proximity Sensor Replacement, Reposition the lens assembly: 步骤 34 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement, Reposition the lens assembly: 步骤 34 中的图像 2,2
    • Pull the two lenses outward so they're as far apart as possible.
  35. HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the lens assembly: 步骤 35 中的图像 1,1
    • Use a T5 Torx screwdriver to remove the four screws securing the lens assembly:
    • Three 4.9 mm‑long screws
    • One 3.3 mm‑long screw
  36. HTC Vive XR Elite Proximity Sensor Replacement, Remove the brackets: 步骤 36 中的图像 1,3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the brackets: 步骤 36 中的图像 2,3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the brackets: 步骤 36 中的图像 3,3
    在这个步骤中使用的工具:
    • The screw brackets are secured with clips and adhesive.
    • Use tweezers to pull the left screw bracket of its post in the frame.
    • This may require some force. Be careful not to scratch any surrounding components.
    • Repeat this process for the right bracket.
    • During reassembly, use tweezers to align the brackets on their posts. Press down with the flat end of a spudger to engage and re-adhere the clips.
  37. HTC Vive XR Elite Proximity Sensor Replacement, Reposition the lens assembly: 步骤 37 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement, Reposition the lens assembly: 步骤 37 中的图像 2,2
    • Lift the bottom of the lens assembly up to separate the bottom rails from their slots in the frame.
  38. HTC Vive XR Elite Proximity Sensor Replacement: 步骤 38 中的图像 1,3 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 38 中的图像 2,3 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 38 中的图像 3,3
    • Pull the lens assembly upwards to separate the top rails from their slots in the frame.
    • Rotate the lens assembly towards the top of the frame so it sits upright with its cable connectors exposed.
  39. HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the lens assembly cables: 步骤 39 中的图像 1,1
    • Use a T5 Torx screwdriver to remove the four 3.4 mm‑long screws securing the lens assembly cables.
  40. HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the lens assembly cables: 步骤 40 中的图像 1,3 HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the lens assembly cables: 步骤 40 中的图像 2,3 HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the lens assembly cables: 步骤 40 中的图像 3,3
    • Use the flat end of a spudger to pry up and disconnect the lens assembly cable connector.
    • Repeat this procedure for the other connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  41. HTC Vive XR Elite Proximity Sensor Replacement, Remove the lens assembly: 步骤 41 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement, Remove the lens assembly: 步骤 41 中的图像 2,2
    • Lift up and remove the lens assembly.
  42. HTC Vive XR Elite Proximity Sensor Replacement, Reassembly information: 步骤 42 中的图像 1,3 HTC Vive XR Elite Proximity Sensor Replacement, Reassembly information: 步骤 42 中的图像 2,3 HTC Vive XR Elite Proximity Sensor Replacement, Reassembly information: 步骤 42 中的图像 3,3
    • The next four steps demonstrate how to secure the lens assembly to the frame during reassembly.
    • In order for the lens assembly to rest in the frame properly, it needs to align with a peg in the IPD (interpupillary distance) slider.
    • Before reinstalling the lens assembly, push the IPD slider to its right-most position.
  43. HTC Vive XR Elite Proximity Sensor Replacement: 步骤 43 中的图像 1,3 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 43 中的图像 2,3 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 43 中的图像 3,3
    • Pull the lens assembly outward until its plastic clips sit close to the end of the top rails.
    • You may need to push and pull the top rail so it sits evenly across the plastic clips.
  44. HTC Vive XR Elite Proximity Sensor Replacement: 步骤 44 中的图像 1,3 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 44 中的图像 2,3 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 44 中的图像 3,3
    • Push the bottom rails inwards as far as they will go.
  45. HTC Vive XR Elite Proximity Sensor Replacement: 步骤 45 中的图像 1,3 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 45 中的图像 2,3 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 45 中的图像 3,3
    • To secure the lens assembly into the frame:
    • Slide the top left rail into its slot.
    • Align the other rails.
    • Press the lens assembly into place, making sure to realign the center peg.
  46. HTC Vive XR Elite Proximity Sensor Replacement, Peel the tape: 步骤 46 中的图像 1,3 HTC Vive XR Elite Proximity Sensor Replacement, Peel the tape: 步骤 46 中的图像 2,3 HTC Vive XR Elite Proximity Sensor Replacement, Peel the tape: 步骤 46 中的图像 3,3
    在这个步骤中使用的工具:
  47. HTC Vive XR Elite Proximity Sensor Replacement: 步骤 47 中的图像 1,1
    • Peel off the yellow tape covering the proximity sensor connector.
  48. HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the proximity sensor: 步骤 48 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the proximity sensor: 步骤 48 中的图像 2,2
    • Use the point of a spudger to lift up the locking flap on the proximity sensor ZIF connector.
  49. HTC Vive XR Elite Proximity Sensor Replacement: 步骤 49 中的图像 1,2 HTC Vive XR Elite Proximity Sensor Replacement: 步骤 49 中的图像 2,2
    • Use tweezers to pull the proximity sensor cable out of its slot in the motherboard.
  50. HTC Vive XR Elite Proximity Sensor Replacement, Remove the proximity sensor: 步骤 50 中的图像 1,1
    • Remove the proximity sensor.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
于01/16/22注册
215,039 声望
创作了1,046篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,781篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 208
