跳转到主内容
HTC Vive Pro Facerest Replacement
你所需要的
  1. HTC Vive Pro Facerest Replacement, Reposition the head strap: 步骤 1 中的图像 1,2 HTC Vive Pro Facerest Replacement, Reposition the head strap: 步骤 1 中的图像 2,2
    • Rotate the head strap forward as far as it will go.
  2. HTC Vive Pro Facerest Replacement, Unplug the All-In-One Cable: 步骤 2 中的图像 1,2 HTC Vive Pro Facerest Replacement, Unplug the All-In-One Cable: 步骤 2 中的图像 2,2
    • Unplug the All-In-One Cable from your headset.
  3. HTC Vive Pro Facerest Replacement, Remove the All-In-One Cable: 步骤 3 中的图像 1,3 HTC Vive Pro Facerest Replacement, Remove the All-In-One Cable: 步骤 3 中的图像 2,3 HTC Vive Pro Facerest Replacement, Remove the All-In-One Cable: 步骤 3 中的图像 3,3
    • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
    • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
  4. HTC Vive Pro Facerest Replacement, Remove the top strap: 步骤 4 中的图像 1,2 HTC Vive Pro Facerest Replacement, Remove the top strap: 步骤 4 中的图像 2,2
    • Separate the top strap from itself where the Velcro secures it.
  5. HTC Vive Pro Facerest Replacement: 步骤 5 中的图像 1,3 HTC Vive Pro Facerest Replacement: 步骤 5 中的图像 2,3 HTC Vive Pro Facerest Replacement: 步骤 5 中的图像 3,3
    • Peel back the Velcro securing the rear of the top strap.
    • Feed the top strap out through the head strap to partially remove it.
  6. HTC Vive Pro Facerest Replacement: 步骤 6 中的图像 1,3 HTC Vive Pro Facerest Replacement: 步骤 6 中的图像 2,3 HTC Vive Pro Facerest Replacement: 步骤 6 中的图像 3,3
    • Feed the top strap through the clip near the front of headset to fully remove it.
  7. HTC Vive Pro Facerest Replacement, Remove the front side foam pads: 步骤 7 中的图像 1,3 HTC Vive Pro Facerest Replacement, Remove the front side foam pads: 步骤 7 中的图像 2,3 HTC Vive Pro Facerest Replacement, Remove the front side foam pads: 步骤 7 中的图像 3,3
    • Peel off both front side foam pads to uncover the speaker wires.
  8. HTC Vive Pro Facerest Replacement, Remove the two rubber spacers: 步骤 8 中的图像 1,3 HTC Vive Pro Facerest Replacement, Remove the two rubber spacers: 步骤 8 中的图像 2,3 HTC Vive Pro Facerest Replacement, Remove the two rubber spacers: 步骤 8 中的图像 3,3
    • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
    • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
  9. HTC Vive Pro Facerest Replacement, Disconnect the speaker wires: 步骤 9 中的图像 1,3 HTC Vive Pro Facerest Replacement, Disconnect the speaker wires: 步骤 9 中的图像 2,3 HTC Vive Pro Facerest Replacement, Disconnect the speaker wires: 步骤 9 中的图像 3,3
    • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
  10. HTC Vive Pro Facerest Replacement, Remove the head strap: 步骤 10 中的图像 1,2 HTC Vive Pro Facerest Replacement, Remove the head strap: 步骤 10 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
    • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
    • Four 3.9 mm screws (two on each side)
    • Two 4.1 mm screws (one on each side)
  11. HTC Vive Pro Facerest Replacement: 步骤 11 中的图像 1,1
    • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
  12. HTC Vive Pro Facerest Replacement: 步骤 12 中的图像 1,3 HTC Vive Pro Facerest Replacement: 步骤 12 中的图像 2,3 HTC Vive Pro Facerest Replacement: 步骤 12 中的图像 3,3
    • Thread the headphone speaker wires out through both ends of the head strap.
  13. HTC Vive Pro Facerest Replacement, Remove the outer shell: 步骤 13 中的图像 1,3 HTC Vive Pro Facerest Replacement, Remove the outer shell: 步骤 13 中的图像 2,3 HTC Vive Pro Facerest Replacement, Remove the outer shell: 步骤 13 中的图像 3,3
    • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
  14. HTC Vive Pro Facerest Replacement: 步骤 14 中的图像 1,2 HTC Vive Pro Facerest Replacement: 步骤 14 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
  15. HTC Vive Pro Facerest Replacement: 步骤 15 中的图像 1,3 HTC Vive Pro Facerest Replacement: 步骤 15 中的图像 2,3 HTC Vive Pro Facerest Replacement: 步骤 15 中的图像 3,3
    • Insert an opening pick into the seam between the two halves of the outer shell.
    • Slide the opening pick through the seam to dislodge the clips securing it to the headset.
    • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
  16. HTC Vive Pro Facerest Replacement: 步骤 16 中的图像 1,3 HTC Vive Pro Facerest Replacement: 步骤 16 中的图像 2,3 HTC Vive Pro Facerest Replacement: 步骤 16 中的图像 3,3
    • Continue sliding the opening pick through each seam until all clips have been dislodged.
  17. HTC Vive Pro Facerest Replacement: 步骤 17 中的图像 1,3 HTC Vive Pro Facerest Replacement: 步骤 17 中的图像 2,3 HTC Vive Pro Facerest Replacement: 步骤 17 中的图像 3,3
    • Carefully slide each half of the outer shell off of the sensor array.
    • Be careful not to snag any of the ribbon cables underneath.
  18. HTC Vive Pro Facerest Replacement, Remove the facerest: 步骤 18 中的图像 1,2 HTC Vive Pro Facerest Replacement, Remove the facerest: 步骤 18 中的图像 2,2
    • Partially separate the facerest and the sensor array to access the daughterboard.
  19. HTC Vive Pro Facerest Replacement: 步骤 19 中的图像 1,2 HTC Vive Pro Facerest Replacement: 步骤 19 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the Kapton tape covering the white and purple wires on the daughterboard.
  20. HTC Vive Pro Facerest Replacement: 步骤 20 中的图像 1,3 HTC Vive Pro Facerest Replacement: 步骤 20 中的图像 2,3 HTC Vive Pro Facerest Replacement: 步骤 20 中的图像 3,3
    • Use the pointed end of a spudger to pry up and disconnect the purple and white wires from the daughterboard.
    • Use caution when disconnecting these wires. If you pry up too hard, they may pull out of the connector.
  21. HTC Vive Pro Facerest Replacement: 步骤 21 中的图像 1,2 HTC Vive Pro Facerest Replacement: 步骤 21 中的图像 2,2
    • Slide the facerest out of the front assembly.
结论
另外一个人完成了本指南。
Sam Omiotek
于02/25/19注册
92,525 声望
创作了290篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 1,067
