跳转到主内容
HTC Vive Pro 2 Head Strap Replacement
你所需要的
  1. HTC Vive Pro 2 Head Strap Replacement, Reposition the head strap: 步骤 1 中的图像 1,2 HTC Vive Pro 2 Head Strap Replacement, Reposition the head strap: 步骤 1 中的图像 2,2
    • Rotate the head strap forward as far as it will go.
  2. HTC Vive Pro 2 Head Strap Replacement, Unplug the All-In-One Cable: 步骤 2 中的图像 1,2 HTC Vive Pro 2 Head Strap Replacement, Unplug the All-In-One Cable: 步骤 2 中的图像 2,2
    • Unplug the All-In-One Cable from your headset.
  3. HTC Vive Pro 2 Head Strap Replacement, Remove the All-In-One Cable: 步骤 3 中的图像 1,3 HTC Vive Pro 2 Head Strap Replacement, Remove the All-In-One Cable: 步骤 3 中的图像 2,3 HTC Vive Pro 2 Head Strap Replacement, Remove the All-In-One Cable: 步骤 3 中的图像 3,3
    • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
    • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
  4. HTC Vive Pro 2 Head Strap Replacement, Remove the top strap: 步骤 4 中的图像 1,2 HTC Vive Pro 2 Head Strap Replacement, Remove the top strap: 步骤 4 中的图像 2,2
    • Separate the top strap from itself where the Velcro secures it.
  5. HTC Vive Pro 2 Head Strap Replacement: 步骤 5 中的图像 1,3 HTC Vive Pro 2 Head Strap Replacement: 步骤 5 中的图像 2,3 HTC Vive Pro 2 Head Strap Replacement: 步骤 5 中的图像 3,3
    • Peel back the Velcro securing the rear of the top strap.
    • Feed the top strap out through the head strap to partially remove it.
  6. HTC Vive Pro 2 Head Strap Replacement: 步骤 6 中的图像 1,3 HTC Vive Pro 2 Head Strap Replacement: 步骤 6 中的图像 2,3 HTC Vive Pro 2 Head Strap Replacement: 步骤 6 中的图像 3,3
    • Feed the top strap through the clip near the front of headset to fully remove it.
  7. HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: 步骤 7 中的图像 1,3 HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: 步骤 7 中的图像 2,3 HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: 步骤 7 中的图像 3,3
    • Peel off both front side foam pads to uncover the speaker wires.
  8. HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: 步骤 8 中的图像 1,3 HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: 步骤 8 中的图像 2,3 HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: 步骤 8 中的图像 3,3
    • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
    • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
  9. HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: 步骤 9 中的图像 1,3 HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: 步骤 9 中的图像 2,3 HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: 步骤 9 中的图像 3,3
    • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
  10. HTC Vive Pro 2 Head Strap Replacement, Remove the head strap: 步骤 10 中的图像 1,2 HTC Vive Pro 2 Head Strap Replacement, Remove the head strap: 步骤 10 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
    • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
    • Four 3.9 mm screws (two on each side)
    • Two 4.1 mm screws (one on each side)
  11. HTC Vive Pro 2 Head Strap Replacement: 步骤 11 中的图像 1,1
    • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
  12. HTC Vive Pro 2 Head Strap Replacement: 步骤 12 中的图像 1,3 HTC Vive Pro 2 Head Strap Replacement: 步骤 12 中的图像 2,3 HTC Vive Pro 2 Head Strap Replacement: 步骤 12 中的图像 3,3
    • Thread the headphone speaker wires out through both ends of the head strap.
  13. HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: 步骤 13 中的图像 1,3 HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: 步骤 13 中的图像 2,3 HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: 步骤 13 中的图像 3,3
  14. HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: 步骤 14 中的图像 1,3 HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: 步骤 14 中的图像 2,3 HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: 步骤 14 中的图像 3,3
  15. HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: 步骤 15 中的图像 1,2 HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: 步骤 15 中的图像 2,2
  16. HTC Vive Pro 2 Head Strap Replacement, Remove the head strap: 步骤 16 中的图像 1,2 HTC Vive Pro 2 Head Strap Replacement, Remove the head strap: 步骤 16 中的图像 2,2
  17. HTC Vive Pro 2 Head Strap Replacement: 步骤 17 中的图像 1,1
  18. HTC Vive Pro 2 Head Strap Replacement: 步骤 18 中的图像 1,3 HTC Vive Pro 2 Head Strap Replacement: 步骤 18 中的图像 2,3 HTC Vive Pro 2 Head Strap Replacement: 步骤 18 中的图像 3,3
结论
Alex Diaz-Kokaisl
于01/16/22注册
213,205 声望
创作了1,040篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,638篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 27
总计 246
