跳转到主内容
加入维修社区 - 创建账户
HTC One X Battery Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. HTC One X Battery Replacement, Remove SIM card slot: 步骤 1 中的图像 1,1
    • Insert a safety pin, or other small object in the small opening next to the Sim card slot to remove the SIM card.
    • The Sim Card Slot is located at the top of the rear panel.
    询问修复机器人
    添加评论
  2. HTC One X Battery Replacement, Remove front panel: 步骤 2 中的图像 1,2 HTC One X Battery Replacement, Remove front panel: 步骤 2 中的图像 2,2
    • Using a plastic opening tool, carefully separate the display screen from the rear panel.
    • The display assembly is a tight fit therefore the removal must be carried out carefully with firm, constant force being applied around the bottom corners and sides of the panel. Note that the top of the phone is underneath the panel, and will not come out.
    • If your display is cracked, take extra caution when separating the display from the rear panel to prevent further breakage.
    • Set aside the rear panel.
    询问修复机器人
    添加评论
  3. HTC One X Battery Replacement, Remove the top plastic panel: 步骤 3 中的图像 1,2 HTC One X Battery Replacement, Remove the top plastic panel: 步骤 3 中的图像 2,2
    • Remove the five screws at the top of the panel using a Phillips head screwdriver.
    • Two 2.05mm Philips head screws
    • Three 2.44mm Philips head screws
    • Also remove the screws with the warranty stickers.
    • Once the screws are removed, gently remove the plastic cover using a plastic opening tool to detach the edges from the front panel.
    • Once you have disassembled your device, your warranty will no longer be valid.
    询问修复机器人
    添加评论
  4. HTC One X Battery Replacement, Remove antenna and disconnect the PCB board: 步骤 4 中的图像 1,2 HTC One X Battery Replacement, Remove antenna and disconnect the PCB board: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the two screws at the bottom right corner of the front panel using a Phillips head screwdriver, as shown in the image.
    • Two 3.35mm Philips head screws
    • Use tweezers to disconnect the antenna from the logic board to the PCB board.
    • Remove the tape connected to the motherboard.
    询问修复机器人
    添加评论
  5. HTC One X Battery Replacement, Disconnect the battery and remove PCB board: 步骤 5 中的图像 1,3 HTC One X Battery Replacement, Disconnect the battery and remove PCB board: 步骤 5 中的图像 2,3 HTC One X Battery Replacement, Disconnect the battery and remove PCB board: 步骤 5 中的图像 3,3
    • Remove the tape holding the battery in place.
    • Gently lift the battery from the bottom using a plastic opening tool.
    • You may have to apply heat to melt the glue holding the battery in place.
    • Do not completely remove the battery yet
    • You can now disconnect the flex cable holding the PCB board place. Gently open the gates using tweezers or a plastic opening tool and use tweezers to slide the flex cable out.
    • Now that it's separated, remove and set aside the PCB board.
    询问修复机器人
    添加评论
  6. HTC One X Battery Replacement, Disconnect flex cables: 步骤 6 中的图像 1,3 HTC One X Battery Replacement, Disconnect flex cables: 步骤 6 中的图像 2,3 HTC One X Battery Replacement, Disconnect flex cables: 步骤 6 中的图像 3,3
    • Place the battery back into its original position once the PCB board has been removed
    • Use tweezers to disconnect the power button flex cables.
    • Disconnect the volume flex cable by opening the gate and then sliding the cable out using tweezers.
    • Disconnect the touchscreen flex cable
    • If repairing hard buttons, skip step 7.
    询问修复机器人
    添加评论
  7. HTC One X Battery Replacement, Remove logic board: 步骤 7 中的图像 1,1
    • Disconnect the remaining two flex cables in a similar manner before completely removing the logic board.
    • You may now remove the board safely
    询问修复机器人
    添加评论
  8. HTC One X Battery Replacement, Replace battery: 步骤 8 中的图像 1,1
    • Hold the battery perpendicular to the logic board and simply pull it out to remove it.
    • You can now plug in the new battery.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
Nyles Peterson
于09/22/14注册
1,915 声望
创作了3篇指南
团队
USF Tampa, Team 4-3, Brown Fall 2014 USF Tampa, Team 4-3, Brown Fall 2014 的会员
USFT-BROWN-F14S4G3
3 名成员
创作了26篇指南
1指南评论
Some of these photos heavy really heavy shadows.
Dan Brown - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 32
总计 5,524
